Nagios Alerts
LuisN
Re: Nagios Alerts
Post by LuisN »
Didnt work =\
Removed the retention File, and restarted service. still sending the wrong Host Alias.
abrist
Red Shirt
Re: Nagios Alerts
Post by abrist »
Lets make sure you do not have multiple nagios parents processes:
service nagios stop
ps -aef | grep nagios.cfg
killall nagios
service nagios start
Post the output of the above commands.
LuisN
Re: Nagios Alerts
Post by LuisN »
[root@Mon_Server1 ~]# service nagios stop
Stopping nagios: ....done.
[root@Mon_Server1 ~]# ps -aef | grep nagios.cfg
root 20709 15824 0 14:35 pts/0 00:00:00 grep nagios.cfg
[root@Mon_Server1 ~]# killall nagios
nagios: no process killed
root 20720 15824 0 14:35 pts/0 00:00:00 grep nagios.cfg
[root@Mon_Server1 ~]# service nagios start
Starting nagios: done.
abrist
Red Shirt
Re: Nagios Alerts
Post by abrist »
Still no change?
LuisN
Re: Nagios Alerts
Post by LuisN »
Nada =(
abrist
Red Shirt
Re: Nagios Alerts
Post by abrist »
Is ABC the same as your hostname? Are the issues with just notifications, or with the web UI as well?
LuisN
Re: Nagios Alerts
Post by LuisN »
ABC is the Alias, hostname itself is correct.
abrist
Red Shirt
Re: Nagios Alerts
Post by abrist »
Could you post the service check definition *and* the full command definition?
LuisN
Re: Nagios Alerts
Post by LuisN »
host_name Hosts1
service_description Ping
_SERVICE_ID 16225
use Ping-LAN
its as simple as it gets. that above will not give me the correct Alias, which is tied with the host not the service.
sreinhardt
-fno-stack-protector
Re: Nagios Alerts
Post by sreinhardt »
OK, let's try looking through your configs and objects.cache. I am going to write this as though it is a source based install on Cent, so your directories may vary.
grep -i '[string that you don't want ie. abc]' /usr/local/nagios/var/objects.cache
grep -iR '[string that you don't want ie. abc]' /usr/local/nagios/etc/
grep -i '[string that you do want ie. xyz]' /usr/local/nagios/var/objects.cache
grep -iR '[string that you do want ie. xyz]' /usr/local/nagios/etc/
