NagiosXI version Installation Error
angurisudhakar
Re: NagiosXI version Installation Error
Post by angurisudhakar »
130820 11:02:05 InnoDB: Log file ./ib_logfile0 did not exist: new to be created
InnoDB: Setting log file ./ib_logfile0 size to 5 MB
InnoDB: Database physically writes the file full: wait...
130820 11:02:06 InnoDB: Log file ./ib_logfile1 did not exist: new to be created
InnoDB: Setting log file ./ib_logfile1 size to 5 MB
InnoDB: Doublewrite buffer not found: creating new
InnoDB: Doublewrite buffer created
InnoDB: Creating foreign key constraint system tables
InnoDB: Foreign key constraint system tables created
130820 11:02:06 InnoDB: Started; log sequence number 0 0
130820 11:02:06 [Note] /usr/libexec/mysqld: ready for connections.
Version: '5.0.95' socket: '/var/lib/mysql/mysql.sock' port: 3306 Source distribution
130821 8:50:25 [Note] /usr/libexec/mysqld: Normal shutdown
130821 8:50:25 InnoDB: Starting shutdown...
130821 8:50:26 InnoDB: Shutdown completed; log sequence number 0 43655
130821 8:50:26 [Note] /usr/libexec/mysqld: Shutdown complete
130821 08:50:26 mysqld ended
130821 08:50:33 mysqld started
130821 8:50:33 InnoDB: Started; log sequence number 0 43655
130821 8:50:33 [Note] /usr/libexec/mysqld: ready for connections.
Reason: Keep in mind, bumping posts will only put them at the bottom of our "to reply to" list.
abrist
Red Shirt
Post by abrist »
Well, db *looks* ok. Lets check for apache errors. Run the following tail and leave it running. Then try to add a new command. When it errors out, kill teh tail with ctrl-c and then send the output of teh tail:
tail -f /var/log/httpd/error_log
angurisudhakar
[Thu Aug 29 07:05:04 2013] [error] [client localhost] PHP Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /usr/local/nagiosxi/html/includes/utils-status.inc.php on line 70, referer: http://127.0.0.1/nagiosxi/includes/comp ... -index.php
[Thu Aug 29 07:05:04 2013] [error] [client localhost] PHP Warning: strftime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /usr/local/nagiosxi/html/includes/utilsl.inc.php on line 398, referer: http://127.0.0.1/nagiosxi/includes/comp ... -index.php
abrist
Red Shirt
Post by abrist »
We should stop here for a moment.
When you resolved the php dependencies, did you ever go back and finish the fullinstall?
angurisudhakar
Thanks..for valuable time spending with us..
Post by slansing »
Please answer abrist's question. Did you go back and fullinstall?
angurisudhakar
Remote Linux server SNMP-Traps in NagiosXI server
Hi ,
I have installed NagiosXI Server on cent-OS,
How to Monitor Remote Linux Server SNMP-TRAPS in NagiosXi,If possible please help me out.
Sudhakar Anguri.
Post by slansing »
I would recommend starting with the SNMP trap wizard, navigate to Configure > Configuration Wizards > SNMP Trap Wizard, this should be a easy step by step process. Let us know if you need help.
angurisudhakar
Thanks For your inputs ,But i have little bit confusion here ,How to handle the in put traps in SNMP-Wizard
is there any special configuration required for communication between for remote and NagiosXI server ,If yes please let me know the steps.
Here is a document outlining the additions needed to receive traps in Nagios XI
http://library.nagios.com/library/produ ... -nagios-xi
