but in /etc/nagios-plugin/config/http.cfg:
# 'check_http' command definition
command_name check_http
command_line /usr/lib/nagios/plugins/check_http -H '$HOSTADDRESS$' -I '$HOSTADDRESS$'
# 'check_http_hostname' command definition
command_name check_httpname
command_line /usr/lib/nagios/plugins/check_http -H '$HOSTNAME$' -I '$HOSTADDRESS$'
# 'check_http2' command definition
command_name check_http2
command_line /usr/lib/nagios/plugins/check_http -H '$ARG1$' -I '$HOSTADDRESS$' -w '$ARG2$' -c '$ARG3$'
# 'check_squid' command definition
command_name check_squid
command_line /usr/lib/nagios/plugins/check_http -H '$HOSTADDRESS$' -p '$ARG1$' -u '$ARG2$' -e 'HTTP/1.0 200 OK'
# 'check_https' command definition
command_name check_https
command_line /usr/lib/nagios/plugins/check_http --ssl -H '$HOSTADDRESS$' -I '$HOSTADDRESS$'
# 'check_https_hostname' command definition
command_name check_https_hostname
command_line /usr/lib/nagios/plugins/check_http --ssl -H '$HOSTNAME$' -I '$HOSTADDRESS$'
# 'check_https_auth' command definition
command_name check_https_auth
command_line /usr/lib/nagios/plugins/check_http --ssl -H '$HOSTADDRESS$' -I '$HOSTADDRESS$' -a '$ARG1$'
# 'check_https_auth_hostname' command definition
command_name check_https_auth_hostname
command_line /usr/lib/nagios/plugins/check_http --ssl -H '$HOSTNAME$' -I '$HOSTADDRESS$' -a '$ARG1$'
# 'check_cups' command definition
command_name check_cups
command_line /usr/lib/nagios/plugins/check_http -I '$HOSTADDRESS$' -p 631
# use these checks, if you want to test IPv4 connectivity on IPv6 enabled systems
# 'check_http_4' command definition
command_name check_http_4
command_line /usr/lib/nagios/plugins/check_http -H '$HOSTADDRESS$' -I '$HOSTADDRESS$' -4
# 'check_http_hostname_4' command definition
command_name check_httpname_4
command_line /usr/lib/nagios/plugins/check_http -H '$HOSTNAME$' -I '$HOSTADDRESS$' -4
# 'check_http2_4' command definition
command_name check_http2_4
command_line /usr/lib/nagios/plugins/check_http -H '$ARG1$' -I '$HOSTADDRESS$' -w '$ARG2$' -c '$ARG3$' -4
# 'check_squid_4' command definition
command_name check_squid_4
command_line /usr/lib/nagios/plugins/check_http -H '$HOSTADDRESS$' -p '$ARG1$' -u '$ARG2$' -e 'HTTP/1.0 200 OK' -4
# 'check_https_4' command definition
command_name check_https_4
command_line /usr/lib/nagios/plugins/check_http --ssl -H '$HOSTADDRESS$' -I '$HOSTADDRESS$' -4
# 'check_https_hostname_4' command definition
command_name check_https_hostname_4
command_line /usr/lib/nagios/plugins/check_http --ssl -H '$HOSTNAME$' -I '$HOSTADDRESS$' -4
# 'check_https_auth_4' command definition
command_name check_https_auth_4
command_line /usr/lib/nagios/plugins/check_http --ssl -H '$HOSTADDRESS$' -I '$HOSTADDRESS$' -a '$ARG1$' -4
# 'check_https_auth_hostname_4' command definition
command_name check_https_auth_hostname_4
command_line /usr/lib/nagios/plugins/check_http --ssl -H '$HOSTNAME' -I '$HOSTADDRESS$' -a '$ARG1$' -4
# 'check_cups_4' command definition
command_name check_cups_4
command_line /usr/lib/nagios/plugins/check_http -I '$HOSTADDRESS$' -p 631 -4
}Code: Select all
hostgroup_name servers
service_description HTTP Conection
check_command check_http!192.168.120.1!5!8
