Real time Alerts monitoring
Re: Real time Alerts monitoring
It should show then in the logs. It is possible that it took 7 min before your alert was delivered.
Sep 1 21:52:37 localusarad sendmail[16003]: r821qbtb016003:
ocalhost.localdomain>, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
ler=relay, pri=31354, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (r821qbtb016003 Message accepted for delivery)
lrivertech.com. [169.131.130.19], dsn=2.0.0, stat=Sent (Ok: queued as F3FF512C065)
f
lhost.localdomain>, relay=nagios@localhost
It is quite a long time but it is not impossible. I don't have another logical explanation at the moment. I would keep an eye on the log and alerts for a while to determine if there is any pattern.
