Monitoring network device which can send SNMP Trap
sreinhardt
-fno-stack-protector
Re: Monitoring network device which can send SNMP Trap
Post by sreinhardt »
Initial changes or additions that should be made:
snmptt.ini
Mode = daemon
unknown_trap_log_enable = 1
snmptt_conf_files = <<END
/etc/snmp/snmptt.conf.tv
END
(Not sure why your snmptt.conf has the .tv added, but this may be preventing some mib additions from working properly.
snmptrapd.conf
disableAuthorization yes
snmptt.conf.tv (your way may be possible but we recommend using snmptraphandler.py like below for exec lines)
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "The newRoot trap indicates that the sending agent has $*"
phyolwin
Post by phyolwin »
Thanks for your reply.
Actually I just followed the instruction from below link.
http://goo.gl/W5nYZ7
That why my configuration file becomes snmptt.conf.tv
But it is not working.
Previously I also followed nagios documentation.
http://goo.gl/kLo0Sw
I will install new os and make new configuration and let you know.
I didn't understand well about EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "The newRoot trap indicates that the sending agent has $*". Could you explain it a bit more. :D
phyolwin wrote:Previously I also followed nagios documentation.
If you followed this guide you should have the following at the bottom of snmptt.ini
[TrapFiles]
# A list of snmptt.conf files (this is NOT the snmptrapd.conf file).  The COMPLETE path
# and filename.  Ex: '/etc/snmp/snmptt.conf'
/usr/share/snmp/mibs/processed_mibs/dcmcuMIB.txt
END
This document if followed will import current mibs, and you need to add new mibs with the
addmib
command described in the document.
This procedure builds the EXEC /usr/local/bin/snmptraphandling.py portion which is what is used to send the data to Nagios XI
