installation issue on Debian Wheezy
Re: installation issue on Debian Wheezy
Please file a bug on http://tracker.nagios.org. It looks like the init script is not currently working for ubuntu/debian systems.
Great. Keep an eye on this thread. I am hoping mlong can post his current working debian init script.
Cant find any init-script.debian in source dir.
Any help ??
Ty
Any help ??
Ty
turrete, please open a new thread dedicated to your issue, outline what you have done and what your current problem is, that way we can keep this thread on track and clutter free, thank you..
The init script (/etc/init.d/nagios) have to be well modified.
I also removed the '-d 10' option applied on killproc in the stop sequence (around line 94) to avoid error message on 'service nagios stop' call.
sudo apt-get install daemon
sudo sed -i 's/^\.\ \/etc\/rc.d\/init.d\/functions$/\.\ \/lib\/lsb\/init-functions/g' /etc/init.d/nagios
sudo sed -i 's/status\ /status_of_proc\ /g' /etc/init.d/nagios
sudo sed -i 's/daemon\ --user=\$user\ \$exec\ -ud\ \$config/daemon\ --user=\$user\ --\ \$exec\ -d\ \$config/g' /etc/init.d/nagios
sudo sed -i 's/\/var\/lock\/subsys\/\$prog/\/var\/lock\/\$prog/g' /etc/init.d/nagios
sudo sed -i 's/\/sbin\/service\ /\/usr\/sbin\/service\ /g' /etc/init.d/nagios
sudo sed -i 's/runuser/su/g' /etc/init.d/nagios
sudo service nagios start
Thanks Nicolargo on stackoverflow !$Stopping nagios: Illegal option -d
/sbin/start-stop-daemon: signal value must be numeric or name of signal (KILL, INT, ...)
Try '/sbin/start-stop-daemon --help' for more information.
