Starting nagios, localhost appears DOWN
volpeadmin
Re: Starting nagios, localhost appears DOWN
Post by volpeadmin »
/etc/init.d/nagios ...attached (changed file extension to known file type)
nagios.txt
(5.19 KiB) Downloaded 586 times
BTW, can you run the following command and see if this is going to fix your issue?
usermod -s /bin/bash nagios
volpeadmin
I think that did it! "Nagios" user needed the bash shell..
# service nagios restart
Running configuration check...done.
Stopping nagios: done.
Starting nagios: done.
(no error.)
Thanks a bunch!
Post by slansing »
Ah excellent, thanks for letting us know!
