Not All Report Create PDFs
jomann
Development Lead
Re: Not All Report Create PDFs
Post by jomann »
Hi Mike,
With this recently upgraded system you mentioned with the logs, do the reports work in the PHP pages in XI?
If you were to use the link you gave without the &hideoptions=1 what does it give?
Mike,
Try jomann's suggestion and let us know of the result. We can also talk about this during the conference.
mikew
Post by mikew »
No these are two different systems. One that worked, 2012R2.2 to 2.4. One that did not work, 2012R2.3 to 2.4.
The one that did not work had some PDFs that worked and some that did not, now none work, all empty.
The one that worked I commented out the languages as mentioned before.
Mike Weber
Nagios Training/Consulting
jomann
Development Lead
Post by jomann »
So what I think is going on is wkhtmltopdf is having trouble on your box - which is what was used to make the PDF for executive summary and all scheduled reports before the 2012R2.4 release. Now we use it for all the reporting including the PDFs for the reports that were using FPDF.
Can you check the version of wkhtmltopdf on your box?
wkhtmltopdf --version
We have to use 0.10.0 rc2 because it has some Qt integration that is not in the newer version so if yours is newer that could be the cause.
If you need to install wkhtml, you can run:
cd /tmp/nagiosxi/subcomponents/wkhtml
./install
mikew
Post by mikew »
Thanks...it is a production machine so I cannot get access to it until Thursday (enjoying the Nagios conference) but I will check it out and put an update in here in case it happens to anyone else.
Mike Weber
Sounds good, Mike.
mikew
Post by mikew »
Here is an update on this issue:
At this point an install fails as listed below. Install done from the subcomponents//wkhtml/ directory.
Name:
wkhtmltopdf 0.10.0 rc2
./install
Traceback (most recent call last):
File "./install", line 17, in <module>
installpath = os.environ['INSTALL_PATH']
File "/usr/lib/python2.6/UserDict.py", line 22, in __getitem__
raise KeyError(key)
KeyError: 'INSTALL_PATH'
Mike Weber
Mike,
Copy the file below over the "old" install script in "/tmp/nagiosxi/subcomponents/wkhtml" (remove the *.txt extension first)
install.txt
and run:
./install
Let me know if this helped.
mikew
Post by mikew »
I removed the old install and ran the new one...it did not make any difference. All reports are a white page when you select reports and PDFs. The version has stayed the same:
Name:
Mike Weber
