Yes.Which I believe means that the NRPE is Running and working on the Nagios Server right?
Since you talked about multiple ways of installing things (through yum, from source, etc.), it's unclear which result you're actually using, and you may have a mess where multiple copies are installed, pointing to things in different places. You can use the following to check which config file is actually being used by whatever one is running:I did not understand the latter part of your reply.
[root@vs2 ~]# ps aux | grep nrpe
nagios 3843 0.0 0.0 39976 652 ? Ss Feb10 13:27 nrpe -c /etc/nagios/nrpe.cfg -d
