Manual Installation Error
TSCAdmin
Re: Manual Installation Error
Post by TSCAdmin »
no package perl-CPAN available ... Nothing to do
no package php-mcrypt ... Nothing to do
no package php-mssql ... Nothing to do
I don't believe protectbase is causing you any issues here ... The reason why you're getting the errors above is due to the fact that these packages are not included in the DAG or RHEL repositories. They're part of the Centos repos (notice the "Release" info in the code below for the php-* packages).
The manual install method won't work out of the box on a RHEL5 system.
[root@bob tmp]# cat /etc/redhat-release
CentOS release 5.4 (Final)
[root@bob tmp]# yum repolist
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
 * addons: ftp.ussg.iu.edu
 * base: centos.mirror.nac.net
 * epel: archive.linux.duke.edu
 * extras: mirror.nyi.net
 * updates: centos.omnispring.com
repo id                    repo name        status
addons                    CentOS-5 - Addons                                                      enabled:      0
base                       CentOS-5 - Base                                                          enabled:  3,348
dag                         Dag RPM Repository for Red Hat Enterprise Linux         enabled: 10,087
epel                        Extra Packages for Enterprise Linux 5 - x86_64            enabled:  5,243
extra                      CentOS-5 - Extras                                                       enabled:    292
updates                  CentOS-5 - Updates                                                     enabled:    907
repolist: 19,877
[root@bob tmp]# yum info php-mcrypt
Installed Packages
Arch       : x86_64
Version    : 5.1.6
Release    : 15.el5.centos.1
Repo       : installed
Summary    : Standard PHP module provides mcrypt library support
URL        : http://www.php.net/
License    : The PHP License
Description: Standard PHP module provides mcrypt library support
[root@bob tmp]# yum info php-mssql
Installed Packages
Arch       : x86_64
Version    : 5.1.6
Repo       : installed
Summary    : Standard PHP module provides mssql support
Description: Standard PHP module provides mssql support
mmestnik
Post by mmestnik »
Ohh sorry. These are not errors and are the result of our support for Fedora and RedHat. Some of the steps along the way are done twice and it's expected that one of the two attempts will fail on the other operating system. :mrgreen:
Sorry for the confusion.
