Sorry Dave, I can't let you do that error
Re: Sorry Dave, I can't let you do that error
what do you mean terminal window. I onnect via putty run date command i AM GETTING THE same dtae and time. How about data not populating in the table I mentioned before.
Try restarting both msql and postgresql
service mysqld restart
service postgresql restart
It seems like nagios is not storing data in nagios_servicechecks table because it is the only table empty. Please verify that and let me know because after following all your instructions and directions i am still get no data in that table. In addition, that silly message Dave is still there.
To get back to the "time change" that was done. How did you synchronize it via putty? I would suggest something of this nature if you haven't already:
Managing Nagios Time
The correct time on a server is critical, especially for Nagios. Synchronized time with other servers is important to
coordinate tasks and discover problems. One easy way to perform this task is to install ntp (Network Time Protocol)
and then manually have the system check time once a day in order to manage time.
yum install y ntp
Manually update your time. Here you can see the system is off by 12 seconds so it will be corrected gradually with
each check.
ntpdate pool.ntp.org
11 Mar 12:09:55 ntpdate[24725]: step time server 192.168.*.* offset 10900.806712 sec
12 sec
Create a cron entry so that each day your system is brought up to date.
crontab e
45 23 * * * /usr/sbin/ntpdate pool.ntp.org
yum install y ntp
each check.
12 sec
crontab e
I am getting this error after the upgrade.
Lets focus on a single issue at a time. Lets check the PHP timezone settings in your /etc/php.ini file. It's possible the UTC offset is incorrect for PHP.
http://support.nagios.com/wiki/index.ph ... e.22_Error
Try running the following scripts as well to make sure your backend is functioning properly.
/usr/local/nagiosxi/scripts/repairmysql.sh nagios *
/usr/local/nagiosxi/tools/fix_postgres_sequences.sh
I have changed the date.timezone since last week.
It looks like the servers were busy, please try again for that to be sure. It should look like this:
This is also a VM.
This is also a VM.
I havr tried again but no luck
Does your company have a firewall or proxy setup that might be preventing the use of yum? It would appear it's not making contact with the outside world.
Once yum is working, you can run the following commands.
Try:
Once installed, run
Try:
yum install ntpCode: Select all
ntpdate time.nist.gov
