Web Check - Nagios XI
Re: Web Check - Nagios XI
My apologies, I just reread the posts and found that you had done that already. I will try and find out some more information of why this may be happening and report back.
Upon further investigation I am seeing an older version of webinject packaged which can be problematic. I am going to continue to work with this and report back.
Where is the config file in when use wizard. I am unable to find the .xml file to edit is tehre any provison to edit these files from the web UI?
What are you trying to change sujitt?
