unable to add new users in nagios Web interface
abrist
Red Shirt
Re: unable to add new users in nagios Web interface
Post by abrist »
Did you use the web ui to remove the user, or did you remove the user from the db shell? If you removed from the db shell, what was the command?
ravish78
Post by ravish78 »
we deleted the user from gui.
Also deleted his userid from command line
echo "select object_id from nagios_objects,nagios_contacts where object_id=contact_object_id and name1='w3y6rm70';"|mysql -pnagiosxi nagios
echo "select object_id from nagios_objects where name1='w3y6rm70';"|mysql -pnagiosxi nagios
echo "DELETE from nagios_objects where object_id=4780;"|mysql -pnagiosxi nagios
abrist
Red Shirt
Post by abrist »
Can you open a ticket by sending an email to: [email protected] ?
We will need to set up a remote session to look at this problem in more detail.
ravish78
Post by ravish78 »
Sure, We will open ticket for this.
Noted.
ravish78
Post by ravish78 »
you can close this .It is resolved
