[SOLVED] Notifications never attempted
Re: Notifications never attempted
Can you post the service and contact definitions? You can remove the sensitive info.
CCM->Services-><your service>->View Text Config
CCM->Services-><your contact>->View Text Config
belvdr
Post by belvdr »
lmiltchev wrote:Can you post the service and contact definitions? You can remove the sensitive info.
Here you go. I really appreciate the help.
host_notification_options d,u,r,f,s,n,
service_notification_options w,u,c,r,f,s,n,
If you specify n (none) as an option, the contact will not receive any type of host/service notifications. Clear the "n" box under the CCM (Contact Management), save and apply configuration. Hope this helps.
belvdr
Post by belvdr »
It's working now! Thank you so much everyone for your assistance. I knew I was overlooking something simple.
