ls -la /tmp/linux-nrpe-agent/ | grep -i install
touch /tmp/linux-nrpe-agent/installed.yum
Ah you most certainly appear to be well past the 0-yum stage. Each of those installed.xxx is a file for us to check and see how far along you are. It looks like you should be on firewall configuration at this point, with only one step left. If it is in fact stopping at 0-yum still, I would suggest sending me the install.log and I can look it over.
OK it looks like you are having issues with the command 'service iptables save'. Do you know has fedora swapped to systemctl\systemd yet? Regardless, you can comment out line 31 of 4-firewall and should be able to get past. You are very nearly done, although it seems we may need to consider some updating of the install script to work with newer fedora versions and soon Cent\RHEL when they make similar changes.
