Extra note for host and services
veenm
Re: Extra note for host and services
Post by veenm »
Could you please tell me the format for the URL , I have given like below , but when i try to open it gives me a a error. what i am missing here
notes_url http://nagios_ipaddress/nagios/pnp/index.php?host=$HOSTNAME$
note_url display as a piece of paper icon or red folder icon please confirm.
abrist
Red Shirt
Post by abrist »
What is the error, be as verbose as possible?
veenm
Post by veenm »
getting the below error.
Not Found
The requested URL /nagios/pnp/index.php was not found on this server.
Apache/2.2.15 (Red Hat) Server at xxx Port 80
sreinhardt
-fno-stack-protector
Post by sreinhardt »
I doubt you are able to pass the $HOSTNAME$ macro into the note, and have it output as the actual hostname for that host. Macros are not normally interpreted for notes as far as I know. Does it work properly if you enter the actual name that pnp has for that host?
veenm
Post by veenm »
When you say "Does it work properly if you enter the actual name that pnp has for that host" what does mean. Please tell me how to create the url , how should i create a URL format.
what configuration that i have to make to see the extra folder in red color in the host details.
Please let me know.
If instead of $HOSTADDRESS$ you manually put in the host name, such as "localhost". For example:
http://nagios_ipaddress/nagios/pnp/index.php?host=localhost
This is just an example. You should replace "localhost" with the name of the host.
veenm
Post by veenm »
If i want to add extra host information like ( server owner , type of host ..etc. ) on host details then how do i do that using nagios core....
veenm,
You can use custom object variables
http://nagios.sourceforge.net/docs/3_0/ ... tvars.html
