echo "UNKNOWN - $RESULT proc found ."
exit $STATE_UNKNOWN
What was the output when you ran it as nagios, I'd change the group perms on the perm file to Apache as nagios should be a part of the Apache group and this would remove the possibility of it being a web permissions issue? I'd also recommend changing your exits to not say "proc found" if it does not actually find the proc.
You likely need to change the $HOSTADDRESS$ to match your root@ portion from when you ran it as the nagios user. If you are just using the hostname or IP, it doesn't know what user to attempt to login as. (./check_logstash.sh -H root@openx-dist1d -p /usr/local/nagios/x.pem)
