Fix for livestatus icw nagios 4
sreinhardt
-fno-stack-protector
Re: Fix for livestatus icw nagios 4
Post by sreinhardt »
can you provide the exact steps that you followed from downloading source files to building the binaries please?
You can search system messages for errors, related to livestatus:
grep livestatus /var/log/messages
Most probably the module didn't load. I believe you need to change this:
broker_module=/usr/local/lib/mk-livestatus/livestatus.o /var/lib/nagios/rw/live
to this:
broker_module=/usr/local/lib/mk-livestatus/livestatus.o /usr/local/nagios/var/rw/live
Note: Other words, you need to put "live" into the same directory as the Nagios pipe.
Restart nagios and check to see if the module loaded successfully:
service nagios restart
Mike-sbg
Post by Mike-sbg »
This post is rather old, but did you get it working, without crashes of the nagios core.
I didn't have luck ... Nagios 4.2 crashes every few hours, when I use mk-livestatus
Mike, I will be locking this post as you have another one open on the same issue already: https://support.nagios.com/forum/viewto ... 6&start=10, and a post on GitHub: https://github.com/NagiosEnterprises/na ... issues/299.
