NRPE client configuration on HP-UX
Re: NRPE client configuration on HP-UX
I restart the daemon xinetd that contained the nrpe whit the command:
service xinetd restart.
After restarting xinetd, please run another check to the HP-UX system. Afterwards, post the ouput of the log:
tail -25 /var/adm/syslog/syslog.logFormer Nagios employee
Sorry, in the HP-UX we restart the inetd daemon, because in the hp-ux machine no xinetd.
/sbin/init.d> ps -ef | grep inetd
root 13730 1 0 08:47:07 ? 0:00 /usr/sbin/inetd
root 13829 3913 1 08:47:14 pts/0 0:00 grep inetd
/sbin/init.d> kill -9 13730
/sbin/init.d> ./inetd start
Internet Services started
--At moment in the restart daemon:
/var/adm/syslog> tail -f syslog.log
Dec 12 08:49:39 centauro inetd[17411]: Reading configuration
Dec 12 08:49:39 centauro inetd[17411]: ftp/tcp: Added service, server /usr/lbin/ftpd
Dec 12 08:49:39 centauro inetd[17411]: telnet/tcp: Added service, server /usr/lbin/telnetd
Dec 12 08:49:39 centauro inetd[17411]: login/tcp: Added service, server /usr/lbin/rlogind
Dec 12 08:49:39 centauro inetd[17411]: shell/tcp: Added service, server /usr/lbin/remshd
Dec 12 08:49:39 centauro inetd[17411]: exec/tcp: Added service, server /usr/lbin/rexecd
Dec 12 08:49:39 centauro inetd[17411]: ntalk/udp: Added service, server /usr/lbin/ntalkd
Dec 12 08:49:39 centauro inetd[17411]: auth/tcp: Added service, server /usr/lbin/identd
Dec 12 08:49:39 centauro inetd[17411]: printer/tcp: Added service, server /usr/sbin/rlpdaemon
Dec 12 08:49:39 centauro inetd[17411]: daytime/tcp: Added service, server internal
Dec 12 08:49:39 centauro inetd[17411]: daytime/udp: Added service, server internal
Dec 12 08:49:39 centauro inetd[17411]: time/tcp: Added service, server internal
Dec 12 08:49:39 centauro inetd[17411]: echo/tcp: Added service, server internal
Dec 12 08:49:39 centauro inetd[17411]: echo/udp: Added service, server internal
Dec 12 08:49:39 centauro inetd[17411]: discard/tcp: Added service, server internal
Dec 12 08:49:39 centauro inetd[17411]: discard/udp: Added service, server internal
Dec 12 08:49:39 centauro inetd[17411]: chargen/tcp: Added service, server internal
Dec 12 08:49:39 centauro inetd[17411]: chargen/udp: Added service, server internal
Dec 12 08:49:39 centauro inetd[17411]: kshell/tcp: Added service, server /usr/lbin/remshd
Dec 12 08:49:39 centauro inetd[17411]: klogin/tcp: Added service, server /usr/lbin/rlogind
Dec 12 08:49:39 centauro inetd[17411]: dtspc/tcp: Added service, server /usr/dt/bin/dtspcd
Dec 12 08:49:39 centauro inetd[17411]: swat/tcp: Added service, server /opt/samba/bin/swat
Dec 12 08:49:39 centauro inetd[17411]: registrar/tcp: Added service, server /etc/opt/resmon/lbin/registrar
Dec 12 08:49:39 centauro inetd[17411]: hacl-probe/tcp: Added service, server /opt/cmom/lbin/cmomd
Dec 12 08:49:39 centauro inetd[17411]: hacl-cfg/udp: bind: Address already in use
Dec 12 08:49:39 centauro inetd[17411]: hacl-cfg/udp: Added service, server /usr/lbin/cmclconfd
Dec 12 08:49:39 centauro inetd[17411]: hacl-cfg/tcp: Added service, server /usr/lbin/cmclconfd
Dec 12 08:49:39 centauro inetd[17411]: omni/tcp: Added service, server /opt/omni/lbin/inet
Dec 12 08:49:39 centauro inetd[17411]: recserv/tcp: Added service, server /usr/lbin/recserv
Dec 12 08:49:39 centauro inetd[17411]: nrpe/tcp: Added service, server /opt/iexpress/nagios/bin/nrpe
Dec 12 08:49:39 centauro inetd[17411]: rpc.cmsd/udp: Added service, server /usr/dt/bin/rpc.cmsd
Dec 12 08:49:39 centauro inetd[17411]: rpc.ttdbserver/tcp: Added service, server /usr/dt/bin/rpc.ttdbserver
Dec 12 08:49:39 centauro inetd[17411]: Configuration complete
--In the nagios machines:
[root@nagios libexec]#./check_nrpe -H 192.168.42.129 -c check_correlacion -a /usr/local/nagios/libexec/fichero.txt "1800 integraci+"
CHECK_NRPE: Received 0 bytes from daemon. Check the remote server logs for error messages.
----In hp-ux the result in syslog when I exectue the command ./check_nrpe -H 192.168.42.129 -c check_correlacion -a /usr/local/nagios/libexec/fichero.txt "1800 integraci+"
/var/adm/syslog> tail -f syslog.log:
Dec 12 08:55:58 centauro nrpe[29519]: Error: Request contained command arguments!
Dec 12 08:55:58 centauro nrpe[29519]: Client request was invalid, bailing out...
Note:
When I stop the inetd daemon, and I execute in nagios
. / check_nrpe -H IP.machine.hpux
Connection refuse by host
Note:
This is expected if inetd is managing the nrpe daemon and inetd is stopped.RDMaroto wrote:Note:
One of the following is most likely the cause:RDMaroto wrote:/var/adm/syslog> tail -f syslog.log:
1) "dont_blame_nrpe=1" is not set in nrpe.cfg on the HP-UX.
2) the nrpe daemon has not been restarted since adding "dont_blame_nrpe=1" to the HP-UX's nrpe.cfg:
3) multiple nrpe processes are running on the HP-UX.
Thanks abrist.
How I can check if I started nrpe?
If I do in hpux machine
ps-ef | grep nagios
nagios 4117 1 0 17:57:36? 0:00 / opt / iexpress / nagios / bin / nagios-d / opt / iexpress / nagios / etc / nagios.cfg
nagios 15569 21179 0 18:03:54 pts / 0 0:00 grep nagios
but If I do in hpux machine
ps-ef | grep nrpe
nagios 17251 21179 0 18:04:39 pts / 0 0:00 grep nrpe
I understand that he is running because the devil run from nagios:
. / check_nrpe-H ip.machine.hpux
NRPE v2.12
But, how do I reset it?
/opt/iexpress/nagios/bin> ls
nagios nagiostats nrpe nsca
centauro(root):/opt/iexpress/nagios/bin> ./nrpe start
NRPE - Nagios Remote Plugin Executor
Copyright (c) 1999-2008 Ethan Galstad ([email protected])
Version: 2.12
Last Modified: 03-10-2008
License: GPL v2 with exemptions (-l for more info)
SSL/TLS Available: Anonymous DH Mode, OpenSSL 0.9.6 or higher required
** POSSIBLE SECURITY RISK - TCP WRAPPERS ARE NOT AVAILABLE! **
** Read the NRPE SECURITY file for more information **
Usage: nrpe [-n] -c <config_file> <mode>
Options:
-n = Do not use SSL
<config_file> = Name of config file to use
<mode> = One of the following two operating modes:
-i = Run as a service under inetd or xinetd
-d = Run as a standalone daemon
Notes:
This program is designed to process requests from the check_nrpe
plugin on the host(s) running Nagios. It can run as a service
under inetd or xinetd (read the docs for info on this), or as a
standalone daemon. Once a request is received from an authorized
host, NRPE will execute the command/plugin (as defined in the
config file) and return the plugin output and return code to the
check_nrpe plugin.
centauro(root):/opt/iexpress/nagios/bin> ./nrpe -i
root 27169 14248 1 18:09:57 pts/4 0:00 grep nrpe
centauro(root):/opt/iexpress/nagios/bin> ./nrpe -d
centauro(root):/opt/iexpress/nagios/bin> ps -ef | grep nrpe
root 27929 14248 1 18:10:12 pts/4 0:00 grep nrpe
The error in nagios continue...
Thanks for your time abrist
ps-ef | grep nagios
ps-ef | grep nrpe
NRPE v2.12
Version: 2.12
Options:
-n = Do not use SSL
Notes:
check_nrpe plugin.
The nrpe daemon on the remote host should be restarted when inetd is restarted. If you stop inetd, you should not be able to check the nrpe version from the nagios server:
1) kill inetd (stop the service, etc)
2) Try to check the nrpe version from the XI server once again - it should not work this time:
3) Restart inetd.
. / check_nrpe-H ip.machine.hpuxFormer Nagios employee
Good morning abrist.
I execute in HPUX:
ps -ef | grep inetd
root 6863 15889 0 08:38:14 pts/5 0:00 grep inetd
root 26857 1 0 08:54:31 ? 0:31 /usr/sbin/inetd
/sbin/init.d> kill -9 26857
root 7488 15889 0 08:38:25 pts/5 0:00 grep inetd
In this moment in NAGIOS:
./check_nrpe -H IP.MACHINE.HPUX
Connection refused by host
Restart inetd in HPUX:
And execute in NAGIOS:
NRPE v2.12
And execute also in NAGIOS:
./check_nrpe -H IP.MACHINE.HPUX -c check_correlacion -a /opt/iexpress/nagios/etc/nrpe.cfg "test one"
Regards
I execute in HPUX:
ps -ef | grep inetd
NRPE v2.12
Regards
You most likely have argument mismatch issues. See section "V. CHECK_NRPE: Received 0 bytes from daemon. Check the remote server logs for error
messages" from the following document:
http://assets.nagios.com/downloads/nagi ... utions.pdf
Good morning abrist
I performed all the steps in the document. pdf and the result is always the same.
What is the problem in hp-ux machines?
At my company we bought the license nagios, and this point is very important monitoring
Thanks for your time.
Regards
Regards
If you have paid for support for XI, send an email to [email protected] to open a ticket. We may move to a remote session.
