Can't create a new host.
Re: Can't create a new host.
I didn't find anything weird in the logs. Go to Admin->Reset Security Credentials and click on the "Update Credentials" without changing anything else. Let us know if this resolved your issue.
I've update credentials but it doesn't work.
Thanks.
Thanks.
Can you run the following procedure and post the results
http://support.nagios.com/wiki/index.ph ... n_Problems
Also, can you verify that you have all green in Admin -> System Status and Admin -> Monitoring Engine Status
My nagios xi status.
Thanks.
Thanks.
Here's the logs. I'm apply with one host creating.
Thanks.
Thanks.
sreinhardt
- -fno-stack-protector
Locking, for future reference this was due to not having RWX on /usr/local/nagios/etc/import/ for nagios and apache users\group.
