nagios service fails to start
abrist
Red Shirt
Re: nagios service fails to start
Post by abrist »
It looks like fedora 19 changed the way they deal with LSB init functions - we will have to wait for a proper fix from the core devs. Have you filed a bug report at: http://tracker.nagios.org
Is running this on fedora 19 a requirement? We tend to suggest centos.
feltron_cq
Post by feltron_cq »
abrist wrote:It looks like fedora 19 changed the way they deal with LSB init functions - we will have to wait for a proper fix from the core devs. Have you filed a bug report at: http://tracker.nagios.org
No I haven't.
abrist wrote:Is running this on fedora 19 a requirement? We tend to suggest centos
I have a fedora box available, whereas I would have to create a new Centos one. Therefore I would prefer to stick with fedora
I would recommend filing a bug report so that the issue won't "fall in the cracks".
feltron_cq
lmiltchev wrote:I would recommend filing a bug report so that the issue won't "fall in the cracks".
OK have done
Post by slansing »
Thank you, you will be updated on that tracker post as events unfold.
