no job control in this shell as a warning return
vivithemage
Re: no job control in this shell as a warning return
/sbin/nologin is all garbled, possibly a system file?
What should I see in etc/passwd ? nothin grelated to TTY there.
Apologies, you should check /etc/passwd for /sbin/nologin for the user nagios. Though, something must have changed on the remote system.
vivithemage
What is needed on the remote box for the check exactly? what exactly does nagios send to the server, doe she need specific credentials or something?
I believe abrist is referring to the remote host's nagios user. NRPE does not require specific credentials or anything of the sort from nagios as it's commands are executed through the remote system's nagios user.
Run the following commands and show us the output:
On the remote server:
Note: the path to your nagios plugins could be different - modify your command accordingly.
On the nagios server:
/usr/local/nagios/libexec/check_procs -w 150 -c 200On the nagios server:
./check_nrpe -H <remote server IP>
./check_nrpe -H <remote server IP> -c <command defined on the remote machine>Be sure to check out our Knowledgebase for helpful articles and solutions!
vivithemage
I am not sure what the deal is, but I cannot seem to find the libexec directory ...
[root@madhost500vm2 /]# cd /etc/nagios
[root@madhost500vm2 nagios]# ls
cgi.cfg htpasswd.users madhosted nagios.cfg.rpmnew nrpe.cfg resource.cfg
cgi.cfg.rpmnew madgenius nagios.cfg nagios.tar objects resource.cfg.rpmnew
Is it not in:
What distro are you running?
/usr/local/nagios/libexec-
vivithemage
I don't have a nagios dir in /usr/local ... I don't think it was a source install, probably an RPM.
CentOS release 5.9 (Final)
Please run
find / -name libexecFormer Nagios employee
vivithemage
duhhhhhhhh, thanks haha.
none have check_procs though:
[root@madhost500vm2 /]# find / -name libexec
/usr/local/pnp4nagios/libexec
/usr/local/libexec
/usr/libexec
this does:
[root@madhost500vm2 /]# find / -name check_procs
/usr/lib64/nagios/plugins/check_procs
so here are some results:
[root@madhost500vm2 /]# /usr/lib64/nagios/plugins/check_procs -w 150 -c 200
PROCS OK: 126 processes
[root@madhost500vm2 /]# /usr/lib64/nagios/plugins/check_nrpe -H madhost409.madgenius.com
NRPE v2.12
[root@madhost500vm2 /]# /usr/lib64/nagios/plugins/check_nrpe -H madhost419.madgenius.com
NRPE v2.14
madhost409 is the one failing if that matters.
what's the command that I should be running exactly with that -c ? the check I listed above?
/usr/local/libexec
/usr/libexec
this does:
NRPE v2.12
NRPE v2.14
