Nagios XI SNMP collection on discovery mode
Re: Nagios XI SNMP collection on discovery mode
I am getting SNMP results from that host on the Nagios such as syscpu and memcpu and system level snmp
so snmp is set to -v2c and community string too and snmpd enabled
but when doing the process check thru nagios it says connection refused
thanks
thanks
We need to you answer our questions accurately so we can help you. Can you also post the following here:Do you have UDP port 161 open on the remote host? We also need to know what type of system this is, Windows, *nix "if so what distro," etc.
Navigate to Configure > CCM > Services > "click the diskette icon next to your service that is returning the connection refused" and paste the output on that page in a reply here "In code wraps."
here is the results for the host connection refused, collected from disk icon
# Service configuration file
# Created by: Nagios QL Version 3.0.3
# Date: 2013-12-26 11:09:17
# Version: Nagios 3.x config file
# Nagios QL will overwite all manual settings during the next update
host_name 192.168.156.183
service_description / Disk Usage
use xiwizard_nrpe_service
check_command check_nrpe!check_disk!-a '-w 20% -c 10% -p /'
max_check_attempts 5
check_interval 5
retry_interval 1
notification_interval 60
contacts nagiosadmin
_xiwizard linux-server
register 1
service_description /var/log Disk Usage
check_command check_nrpe!check_disk!-a '-w 20% -c 10% -p /var/log'
check_interval 5
retry_interval 5
register 1
service_description Apache Web Server
check_command check_nrpe!check_init_service!-a 'httpd'
check_interval 5
retry_interval 5
register 1
service_description CPU Stats
check_command check_nrpe!check_cpu_stats!-a '-w 85 -c 95'
check_interval 5
retry_interval 5
register 1
service_description Cron Scheduling Daemon
check_command check_nrpe!check_init_service!-a 'crond'
check_interval 5
retry_interval 5
register 1
service_description freeswitch
check_command check_nrpe!check_services!-a 'freeswitch'
check_interval 5
retry_interval 1
register 1
service_description hrSWRunPerfCPU.1629
use xiwizard_snmp_service
check_command check_xi_service_snmp! -p 161 -o hrSWRunPerfCPU.1629 -C DCSZONEA -P 2c -l "RED5 Java" -m HOST-RESOURCES-MIB
check_interval 5
retry_interval 1
_xiwizard snmpwalk
register 1
service_description hrSWRunPerfMem.1629
check_command check_xi_service_snmp! -p 161 -o hrSWRunPerfMem.1629 -C DCSZONEA -P 2c -l "RED5 Java Mem" -m HOST-RESOURCES-MIB
check_interval 5
retry_interval 1
_xiwizard snmpwalk
register 1
service_description Java
use xiwizard_snmp_service,xiwizard_nrpe_service
check_command check_nrpe!check_services!-a 'java'
check_interval 5
retry_interval 5
register 1
service_description Load
check_command check_nrpe!check_load!-a '-w 15,10,5 -c 30,20,10'
check_interval 5
retry_interval 5
register 1
service_description Memory Usage
check_command check_nrpe!check_mem!-a '-w 20 -c 10'
check_interval 5
retry_interval 5
register 1
service_description MySQL Server
check_command check_nrpe!check_init_service!-a 'mysqld'
check_interval 5
retry_interval 5
register 1
service_description Open Files
check_command check_nrpe!check_open_files!-a '-w 30 -c 50'
check_interval 5
retry_interval 5
register 1
service_description red5 Java
check_command check_nrpe!check_services!-a 'red5'
check_interval 5
retry_interval 1
register 1
service_description ssCpuIdle.0
check_command check_xi_service_snmp! -p 161 -o ssCpuIdle.0 -C DCSZONEA -P 2c -m UCD-SNMP-MIB
check_interval 5
retry_interval 1
_xiwizard snmpwalk
register 1
service_description ssCpuRawIdle.0
check_command check_xi_service_snmp! -p 161 -o ssCpuRawIdle.0 -C DCSZONEA -P 2c -m UCD-SNMP-MIB
check_interval 5
retry_interval 1
_xiwizard snmpwalk
register 1
service_description ssCpuRawKernel.0
check_command check_xi_service_snmp! -p 161 -o ssCpuRawKernel.0 -C DCSZONEA -P 2c -m UCD-SNMP-MIB
check_interval 5
retry_interval 1
_xiwizard snmpwalk
register 1
service_description ssCpuRawNice.0
check_command check_xi_service_snmp! -p 161 -o ssCpuRawNice.0 -C DCSZONEA -P 2c -m UCD-SNMP-MIB
check_interval 5
retry_interval 1
_xiwizard snmpwalk
register 1
service_description ssCpuRawSystem.0
check_command check_xi_service_snmp! -p 161 -o ssCpuRawSystem.0 -C DCSZONEA -P 2c -m UCD-SNMP-MIB
check_interval 5
retry_interval 1
_xiwizard snmpwalk
register 1
service_description ssCpuRawUser.0
check_command check_xi_service_snmp! -p 161 -o ssCpuRawUser.0 -C DCSZONEA -P 2c -m UCD-SNMP-MIB
check_interval 5
retry_interval 1
_xiwizard snmpwalk
register 1
service_description ssCpuRawWait.0
check_command check_xi_service_snmp! -p 161 -o ssCpuRawWait.0 -C DCSZONEA -P 2c -m UCD-SNMP-MIB
check_interval 5
retry_interval 1
_xiwizard snmpwalk
register 1
service_description ssCpuSystem.0
check_command check_xi_service_snmp! -p 161 -o ssCpuSystem.0 -C DCSZONEA -P 2c -m UCD-SNMP-MIB
check_interval 5
retry_interval 1
_xiwizard snmpwalk
register 1
service_description ssCpuUser.0
check_command check_xi_service_snmp! -p 161 -o ssCpuUser.0 -C DCSZONEA -P 2c -m UCD-SNMP-MIB
check_interval 5
retry_interval 1
_xiwizard snmpwalk
register 1
service_description SSH Server
check_command check_nrpe!check_init_service!-a 'sshd'
check_interval 5
retry_interval 5
register 1
service_description Swap Usage
check_command check_nrpe!check_swap!-a '-w 50 -c 20'
check_interval 5
retry_interval 5
register 1
service_description System Logging Daemon
check_command check_nrpe!check_init_service!-a 'syslog'
check_interval 5
retry_interval 5
register 1
service_description TomCat Java CPU usage
check_command check_xi_service_snmp! -p 161 -o hrSWRunPerfCPU.1424 -C DCSZONEA -P 2c -m HOST-RESOURCES-MIB
check_interval 5
retry_interval 1
_xiwizard snmpwalk
register 1
service_description TomCat Java Mem
check_command check_xi_service_snmp! -p 161 -o hrSWRunPerfMem.1424 -C DCSZONEA -P 2c -m HOST-RESOURCES-MIB
check_interval 5
retry_interval 1
_xiwizard snmpwalk
register 1
service_description Total Processes
check_command check_nrpe!check_procs!-a '-w 150 -c 250'
check_interval 5
retry_interval 5
register 1
service_description Users
check_command check_nrpe!check_users!-a '-w 5 -c 10'
check_interval 5
retry_interval 5
register 1
# END OF FILE
Reason: Please use code-wraps when posting chunks of data such as the above, as we mentioned previously.
Okay, so there are quite a few service checks beyond what we needed, I was hoping to get the same service configuration that you noted beforehand. If this is in fact a NRPE check is port 5666 open on the remote host? Can you run the following from the nagios CLI and share it's output:
nmap -p 5666,162 <address of remote host>Re: Nagios XI SNMP collection on discovery mode
Here is the attached
thanks in advance
thanks in advance
here is the result
[root@nagios tmp]# nmap -p 5666,162 192.168.156.183
Starting Nmap 5.51 ( http://nmap.org ) at 2013-12-26 12:48 EST
Nmap scan report for 192.168.156.183
Host is up (0.00070s latency).
PORT STATE SERVICE
162/tcp closed snmptrap
5666/tcp closed nrpe
Nmap done: 1 IP address (1 host up) scanned in 0.59 seconds
You have new mail in /var/spool/mail/root
thanks
PORT STATE SERVICE
thanks
it seems I have to install npre agents and plugins to
But we have several of these servers in the Virtual(VMware) form too for a cloud setup
thanks
Ras
thanks
Ras
sreinhardt
- -fno-stack-protector
You are correct, to use check_nrpe, you do need to install the nrpe\nsca agent on the remote system. However there is also the alternative of check_by_ssh, which would only require the plugins or scripts you wish to run, and a user for nagios to login and execute as.
thanks Steven
the mysql process is monitored by nagios successfully, but why cant other apps/processes by monitored by Nagios without any
host installation?
you suggested that
"However there is also the alternative of check_by_ssh, which would only require the plugins or scripts you wish to run, and a user for nagios to login and execute as."
these plugins and scripts are run on the monitored host?
how to do this check_by_ssh and then run the scripts or plugins, where?
please explain?
Ras
host installation?
you suggested that
please explain?
Ras
