ERROR unable to read system id
mohammedqayyum
Re: ERROR unable to read system id
Post by mohammedqayyum »
# cat /etc/*release
LSB_VERSION=base-4.0-amd64:base-4.0-noarch:core-4.0-amd64:core-4.0-noarch:graphics-4.0-amd64:graphics-4.0-noarch:printing-4.0-amd64:printing-4.0-noarch
Red Hat Enterprise Linux Server release 6.5 (Santiago)
Post by slansing »
Have you tried re-registering/subscribing your RHEL installation?
mohammedqayyum
Yeah,still I'm getting the same ERROR unable to read system id.
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Well, fullinstall unlike our XI installer, does not do its own RHEL dependency checks, so this likely is from yum. Can you perform yum commands or do you normally enter something else for a satellite server? you can try:
yum check-update
yum update
mohammedqayyum
I updated YUM,even though still getting the same ERROR unable to read system id. :oops:
sreinhardt
Can you please give us the output of "yum check-update" Also are you using satalite servers or other internal package\license management? Just an fyi I propped up a RHEL 6.3 x86_64 system last night to make sure this was not a global OS issue, and had no issues installing, and also verified that this is likely failing on the yum steps listed in the install.
mohammedqayyum
yum check-update
Loaded plugins: product-id, refresh-packagekit, security, subscription-manager
This system is receiving updates from Red Hat Subscription Management.
rhel-6-server-cf-tools-1-rpms | 2.8 kB 00:00
rhel-6-server-rhev-agent-rpms | 2.9 kB 00:00
rhel-6-server-rpms | 3.7 kB 00:00
sreinhardt
Thanks for the output, this does not answer my question of if you are using strictly the standard repos or internal\satellite servers. Also what method of registration did you use, subscription-manager or rhn_register?(I might have missed this if it was answered above)
mohammedqayyum
I'm using subscription-manager-gui to register and standard repos are internal server.
sreinhardt
OK, I think I found where you are getting hung up. Comment out line 395 in libinstall.sh. It should look like:
	valid_rhel
change it to:
#	valid_rhel
You may still have issues with getting some of the packages from optional channels and outside repos if you only use internal resources, but we can deal with that as it comes along.
