$CONTACTEMAIL$ wouldn't expand to actual value
lkthomas
Re: $CONTACTEMAIL$ wouldn't expand to actual value
Post by lkthomas »
[1389861271.115887] [2048.0] [pid=4089] WARNING: Could not find a macro matching 'CONTACTEMAIL"'!
[1389861271.115895] [2048.0] [pid=4089] WARNING: An error occurred processing macro 'CONTACTEMAIL"'!
command_name notify-host-by-email
command_line /usr/bin/printf "%b" "***** System Alert *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /usr/bin/mailx -r [email protected] -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" "$CONTACTEMAIL"
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Still getting it huh... Could you remove the reference to bin/mailx and instead pipe to a file so that we can see the resulting output from this check?
command_name notify-host-by-log
command_line /usr/bin/printf "%b" "***** System Alert *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" >> /tmp/check_log
