Nagios shows incorrect RAM usage
Re: Nagios shows incorrect RAM usage
Grrrrrreat! Let us know how it goes!
DiegoAnjos
Yep! It works with version 0,4,1,73 2012-12-17
Result from server:
But on this version, instead of NSC.ini you will find nsclient.ini
I had to run these commands so "allow arguments = true" would show up:
Then...
It filled in nsclient.ini with all options. I changed allow arguments = false to "true".
Thanks a lot for your help!
Result from server:
OK: physical memory: 2.09G I had to run these commands so "allow arguments = true" would show up:
cd C:\Program Files\NSClient++Code: Select all
nscp settings --generate --add-defaults --load-allThanks a lot for your help!
Awesome, thanks for keeping us up to date!
