Ok,
I've configured the reboot notification using system uptime service. I've created a new user for this notification that receives only critical alerts i.e. we will be receiving only one alert while the server reboots. Or when the server uptime is less than 1 minutes then it says system rebooted.
As I mentioned in the earlier post, we are using linux-snmp wizard. I've managed to edit the wizard so now it lists the options for uptime too which is good.
While running wizard we are selecting a group to receive notification for the host/services. Once the wizard finishes when I try to edit the notifications settings from Home Page >> Search for Host >> uptime service >>Configure >>Re-configure this service >>Notification. By default its selecting the group but I want to notify the custom user created for reboot alert. It allows me to de-select the group and add the user for notification but in fact the change doesn't come in effect instead it revert back to the group for some reason. But If I do via CCM >> service it saves the settings I made.
Another question:
After I made changes in notification from the CCM for uptime service to alert the user. Its still alerting the group for some reason. please see below for the host and service settings from console.
Host Settings:
define host {
host_name atp-elvprocess3.<our domain>
use xiwizard_linuxsnmp_host
address 10.26.240.117
hostgroups linux-servers
max_check_attempts 5
check_interval 5
retry_interval 1
contact_groups ServerTeam
notification_interval 60
_xiwizard linuxsnmp
register 1
Service settings:
service_description uptime
use Check_Host_Uptime_Linux
check_command check_snmp_uptime_linux!!!!!!!!
max_check_attempts 1
check_interval 1
retry_interval 1
notifications_enabled 1
contacts dlitserverteam
_xiwizard linuxsnmp
register 1
I mean its still sending emails to ServerTeam which it didn't suppose to. All i want is receive notification in dlitserverteam only.
Server reboot notification.
Re: Server reboot notification.
What is the Nagios XI version, that you are currently using? We've fixed a couple of bugs, related to "Configure->Re-configure->Notifications" in 2.8+.
Is the alert that you are receiving a "host" or a "service" alert? The "ServerTeam" contactgroup has been assigned to this host... Can you show us the actual alert that you received?I mean its still sending emails to ServerTeam which it didn't suppose to. All i want is receive notification in dlitserverteam only.
We are currently using the latest available version:lmiltchev wrote:What is the Nagios XI version, that you are currently using? We've fixed a couple of bugs, related to "Configure->Re-configure->Notifications" in 2.8+.
Latest Available Version: 2012R2.9
Installed Version: 2012R2.9
Below is the list of emails we are getting:Is the alert that you are receiving a "host" or a "service" alert? The "ServerTeam" contactgroup has been assigned to this host... Can you show us the actual alert that you received?I mean its still sending emails to ServerTeam which it didn't suppose to. All i want is receive notification in dlitserverteam only.
1st message received by "ServerTeam" contactgroup ::
***** Nagios XI Alert *****
Nagios has detected a problem with this service.
Notification Type: PROBLEM
Service: Uptime
Host: atp-elvprocess3
Address: 10.26.240.213
State: CRITICAL
Info:
System Rebooted at Tue Feb 25 09:49:34 2014
Date/Time: 2014-02-25 09:49:40
2nd message received by 'dlitserverteam' contact:
***** Monitoring System Alert *****
Notification Type: System Reboot
Service: Uptime
State: Rebooted
Info: System Rebooted at Tue Feb 25 09:49:34 2014
3rd message received by "ServerTeam" contactgroup
Nagios has detected this service has recovered.
Notification Type: RECOVERY
Service: Uptime
State: OK
Info:
System hasnt rebooted for 2 minutes
Date/Time: 2014-02-25 09:50:41
I wanted to receive the second message only, as you can see I've customized the message pattern for the user and only critical alert has been enabled with this user just to receive reboot notification.
Let me know if you need any more info
sreinhardt
- -fno-stack-protector
To remove the third(recovery) message, you will want to remove these services from sending recovery messages, and likely only send critical. Just leave only the critical check box checked.
As for the first one, is this service set to notify any other contacts or contact groups in its definitions? I see that the only difference being the info area. Also is this contact set as a contact for the host? It is entirely possible that you are getting duplicate notifications if that is the case, although we should be able to work around that.
Thanks for your reply,
As you can see in my previous posts, the service notification contact is defined as contactname not the contact group. So how is it sending to the group? that's my question.
I know the host notification is going to the group but for this particular service I've modified the contact to send notification to the contact name. Looks like its picking from somewhere else.
Could you please investigate ?
Let me know if more info required.
sreinhardt
If the group, is listed as a contact for the host, it is expected behavior, that they would receive notifications for the service issues as well. Any host contact is considered an admin of that host and will get all service notifications as well, regardless if they are configured specifically for the services or not.
Please note that host contacts and contact groups are only inherited by a service when that service has no contacts or contactgroups defined.
See http://support.nagios.com/forum/viewtop ... ce+contact for more information or like Andy Brist said:
GrtzContacts on a host will *always* be contacts for that host's services except when a contact is defined on the service object itself.
Nagios XI 5.8.1
https://outsideit.net
OK, let's step back and clarify something. You have the service defined as:
The alert is for "Uptime", not "uptime" (which is different):define service {
check_interval 1
retry_interval 1
_xiwizard linuxsnmp
register 1
Just want to verify if this is a typo or you have two different services: "uptime" and "Uptime". The Nagios XI alert *should* display the service name exactly as it is defined... Also, "atp-elvprocess3.<our domain>" is not the same as "atp-elvprocess3"... Can you clarify?***** Nagios XI Alert *****
Service: Uptime
State: CRITICAL
Info:
Sorry for the confusion:lmiltchev wrote:OK, let's step back and clarify something. You have the service defined as:
check_interval 1
retry_interval 1
_xiwizard linuxsnmp
register 1
Service: Uptime
State: CRITICAL
Info:
Its just a typo:
check_interval 1
retry_interval 1
_xiwizard linuxsnmp
register 1
Its lowercase 'uptime'. And we got all hosts defined as fully qualified domains i..e <hostname>.<ourdomain> just wanted to hide the domain name that's all.
let me know if you need more info.
That's my point, if I have defined the contactname for the service explicitly why is it still spamming to the host contact group??, If it is inherited from the host, what's the point of creating service specific contacts?WillemDH wrote:Please note that host contacts and contact groups are only inherited by a service when that service has no contacts or contactgroups defined.
