Email Notifications Logs + Sendmail + not sending
vnc786
Re: Email Notifications Logs + Sendmail + not sending
Post by vnc786 »
Please see this post http://support.nagios.com/forum/viewtop ... 6&start=10
however i tried to get core config snapshot in which there is 2 option in Action [ 1.Download(806MB) 2. View Output(470KB) ]
I can provide you View Output file i think that will be of no use since it just contains service and host name but there are two type of errors in that file which is as follows.."Warning: Service 'Vlan830 Status' on host 'host.local' has no check time period defined!' (this error is for all services )and Warning: Duplicate definition found for service 'Slash Disk Usage' on host 'LSP01' (config file '/usr/local/nagios/etc/services/LSP01 .cfg', starting on line 231) (this error is for 15-20 services)
here is the tail part of "view output"
Checked 4691 services.
Checking hosts...
Checked 145 hosts.
Checking host groups...
Checked 19 host groups.
Checking service groups...
Checked 8 service groups.
Checking contacts...
Warning: Contact 'lagan' has no host notification time period defined!
Checked 25 contacts.
Checking contact groups...
Checked 20 contact groups.
Checking service escalations...
Checking service dependencies...
Checked 0 service dependencies.
Checking host escalations...
Checked 0 host escalations.
Checking host dependencies...
Checked 0 host dependencies.
Checking commands...
Checked 91 commands.
Checking time periods...
Checked 31 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 4343
Total Errors: 0
As a side-note to the current issue, I want to look at that 806MB profile issue. Can you run the following?
ls -lR > output.txt
and PM it to me? I want to see what might be making the download so huge.
vnc786
Post by vnc786 »
tmcdonald wrote:As a side-note to the current issue, I want to look at that 806MB profile issue. Can you run the following?
ls -lR > output.txt
$ du -sh /usr/local/nagios/etc
3.4M   /usr/local/nagios/etc
the issue was with some big :oops: file which was lying in ../etc/.. folder which was making 806MB, now i can download the config snap shot
back to the issue do you need whole config snap shot or part of it ...?
Post by slansing »
Just the actual configuration files, how large is the snapshot?
vnc786
Post by vnc786 »
it is 107KB in .tar.gz format...
also the issue with some services(observed mainly memory related) are not sending email regarding that when services(for now i am considering only 1 particular services) when it first came in GUI (Services Status/ Service=Critical) it is observed that they are already having acknowledge and comment sign PFA
Post by slansing »
Okay, so that acknowledgement will cause alerts not to be sent out, in addition, if it is a sticky acknowledgement notifications will not be sent out until the service fully recovers. Is it possible that a team member is constantly acknowledging them? You can check this via Home > Acknowledgements.
vnc786
Post by vnc786 »
FYI
nagios server uptime : 39days
is nagios service restarted or stop in the middle for a while from the last boot till now? NO
Persistent Comment=sticky ACK
if the services has Persistent Comment where to see ? will it be shown in Home > Acknowledgements if that is the case then for Service which i have posted in image i am not able to see that host name nor services. however i have pasted status.dat(/usr/local/nagios/var/status.dat) of this service please see below
servicestatus {
	host_name=Prod_2
	service_description=Memory Usage
	modified_attributes=1
	check_command=check_xi_service_snmp_win_storage!-C snmpname -m "Real Memory" -r -w 85 -c 95 -f!!!!!!!
	check_period=
	notification_period=24x7
	check_interval=15.000000
	retry_interval=5.000000
	event_handler=
	has_been_checked=1
	should_be_scheduled=1
	check_execution_time=0.218
	check_latency=0.055
	check_type=0
	current_state=2
	last_hard_state=2
	last_event_id=273589
	current_event_id=273663
	current_problem_id=56078
	last_problem_id=56068
	current_attempt=3
	max_attempts=3
	state_type=1
	last_state_change=1390577982
	last_hard_state_change=1390577982
	last_time_ok=1367654673
	last_time_warning=1390577082
	last_time_unknown=1385187866
	last_time_critical=1390816482
	plugin_output=Real Memory: 97%used(31759MB/32768MB) (>95%) : CRITICAL
	long_plugin_output=
	performance_data='Real_Memory'=31759MB;27853;31130;0;32768
	last_check=1390816482
	next_check=1390817382
	check_options=0
	current_notification_number=1
	current_notification_id=1298950
	last_notification=0
	next_notification=0
	no_more_notifications=0
	notifications_enabled=1
	active_checks_enabled=1
	passive_checks_enabled=1
	event_handler_enabled=1
	problem_has_been_acknowledged=1
	acknowledgement_type=2
	flap_detection_enabled=1
	failure_prediction_enabled=1
	process_performance_data=1
	obsess_over_service=1
	last_update=1390816734
	is_flapping=0
	percent_state_change=0.00
	scheduled_downtime_depth=0
	_XIWIZARD=0;solaris
also what does 'problem_has_been_acknowledged=1' above mean ? is it persistent comment ?
vnc786 wrote:if the services has Persistent Comment where to see ? will it be shown in Home > Acknowledgements if that is the case then for Service which i have posted in image i am not able to see that host name nor services.
It will be in the status.dat , something like:
servicecomment{
        host_name=192.168.5.1
        service_description=DHCP
        entry_type=4
        comment_id=706
        source=0
        persistent=0
        entry_time=1387475669
        expires=0
        expire_time=0
        author=Nagios Administrator
        comment_data=Problem is acknowledged
vnc786 wrote: also what does 'problem_has_been_acknowledged=1' above mean ? is it persistent comment ?
It means the service problem has been acknowledged, which may also have a comment.
vnc786
Post by vnc786 »
we have some services which stay in Critical or Warning for long times(1 months or 2 months). talking about the the service in the image(Memory Usage) was for very long time, in View History it was not showing Soft state, there might be the reason that it was showing/Holding ACK sign but i removed the ACK sign from Advance Tab after that i got email...
Also in above thread i have mention 1 attachment which contain State history in which particularly if service goes in Critical State from Warning State particularly ...? what do u think of that...since it is getting recovery
Can you explain me about Persistent Comment and sticky Ack if possible with example ?
sreinhardt
-fno-stack-protector
Post by sreinhardt »
I don't believe that you really can remove an ACK from a problem once it has been ack'd and cause messages to send out again. So if this has been in place for a long time and someone else already ack'd it, I would never expect messages to go out again. I would suggest submitting a passive ok state instead, although that can mess with your reporting a bit. (I could be entirely wrong here too)
Switching between warning, critical, and unknown without a recovery to OK, will not cause any change in length down, retry checks, or notifications. They are all considered a down state and will stay keep most of the same settings and flags, only switching to OK will reset them.
