NagiosXI WMI Monitoring
Re: NagiosXI WMI Monitoring
He replied...he wants to clean it up just a tad and document, so hopefully very soon. I will keep you all posted.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
tgelzaines
Thanks for the response!
Do any of you know if Nagios has any form of asset inventory management built in?
sreinhardt
- -fno-stack-protector
Nope, that is out of the scope of core and XI. You might be able to write a plugin to check various items from other interfaces, but it is not standard.
Updating once again...script should be given to me tomorrow. Also, fyi, this script makes is possible to do this without using a domain admin account. I'll share as soon as I get it.
sreinhardt
Awesome, thanks bandit! Looking forward to seeing what I missed before with wmi permissions..
Ok, here is the script:
WARNING: This does not give the user access to monitor services. That is a separate piece of code I'll get for you all later.
I'll get this up on the exchange sooner or later, maybe wait a bit for feedback from any of you.
This should be pretty sanitized… give it out and see what people think.. .naturally I don’t care, but I can assist if people have problems lol! Purposely absent of error handling or advanced environments… my next revision will be, but this will get those guys going. I attached as a flat file as well, to preserve white spacing. Written by a technical guy for technical guys!!!
##*************** ENABLE NAGIOS - POWERSHELL - AD Integrated **************##
## Lets enable a domain account on a server with WMI cimv2 rights for nagios*
## monitoring, some SDDL permission string creation / modification ......****
## some performance monitoring rights as well. This is intended to use a ***
## domain account as listed below. Script can be modified with for loops to*
## support additoinal domains and accounts. This is simply written to **
## execute with variables below, sorry I don't write like a coder! **
## Thanks, best of luck, and naturally no warranty expressed or implied, **
## use with precaution and don't hold me responsible at all! * **
## THIS VERSION IS WRITTEN WITH NO ERROR HANDLING!!! DOES REQUIRE WMI ACCESS*
Function Set-UserLocalGroup
[cmdletBinding()]
Param(
[Parameter(Mandatory=$True)]
[string]$Computer,
[string]$Group,
[string]$Domain,
[string]$User,
[switch]$add,
[switch]$remove
$de = [ADSI]"WinNT://$Computer/$Group,group"
if($add){
$de.psbase.Invoke("Add",([ADSI]"WinNT://$Domain/$User").path)
} elseif ($remove){
$de.psbase.Invoke("Remove",([ADSI]"WinNT://$Domain/$User").path)
Function get-sid
Param (
$DSIdentity
$ID = new-object System.Security.Principal.NTAccount($DSIdentity)
return $ID.Translate( [System.Security.Principal.SecurityIdentifier] ).toString()
#SID from AD for nagiosXI to apply perms to DCOM level
write-host "`tCapturing SID information for Nagios!"
#use the get-sid command and the netbios domain account to be used... standard domain user permissions.
#function above for get-sid, returns AD sid
#yes this account should be varibalized as it is called below but in the command for group membership you need netbios domain and user seperate.
$sid = get-sid "subdomain\nagiosxi"
$SDDL = "A;;CCWP;;;$sid"
#sets remote launch and activate and local launch. this is where you modify the perms you would like to provide
$DCOMSDDL = “A;;CCDCLCSWRP;;;$sid”
#local computer name to reference... remote calls do not always work.
#$strcomputer = $env:COMPUTERNAME
# remote call it, easily wrapped into a foreach for a list of server names, depending on deployment, add a domain based lookup for multiple domains.
##### VARIABLE TO BE SET #####
$strcomputer = "hostmachine1.subdomain.domain.com"
#Where am I?
write-host "`nWorking on $strcomputer..."
#Modify Launch permissions... all through registry...
$Reg = [WMIClass]"\\$strcomputer\root\default:StdRegProv"
$DCOM = $Reg.GetBinaryValue(2147483650,"software\microsoft\ole","MachineLaunchRestriction").uValue
$security = Get-WmiObject -ComputerName $strcomputer -Namespace root/cimv2 -Class __SystemSecurity
$converter = new-object system.management.ManagementClass Win32_SecurityDescriptorHelper
$binarySD = @($null)
$result = $security.PsBase.InvokeMethod("GetSD",$binarySD)
write-host "`tConverting current permissions to SDDL format..."
$outsddl = $converter.BinarySDToSDDL($binarySD[0])
$outDCOMSDDL = $converter.BinarySDToSDDL($DCOM)
$newSDDL = $outsddl.SDDL += "(" + $SDDL + ")"
write-host "`tBuilding the new permissions..."
$newDCOMSDDL = $outDCOMSDDL.SDDL += "(" + $DCOMSDDL + ")"
$WMIbinarySD = $converter.SDDLToBinarySD($newSDDL)
$WMIconvertedPermissions = ,$WMIbinarySD.BinarySD
$DCOMbinarySD = $converter.SDDLToBinarySD($newDCOMSDDL)
$DCOMconvertedPermissions = ,$DCOMbinarySD.BinarySD
write-host "`tApplying changes..."
$result = $security.PsBase.InvokeMethod("SetSD",$WMIconvertedPermissions)
$result = $Reg.SetBinaryValue(2147483650,"software\microsoft\ole","MachineLaunchRestriction", $DCOMbinarySD.binarySD)
# add WMI perms Add nagiosXI Account to the CIMV2 perms
#WMI Permission - Enable Account, Remote Enable for This namespace and subnamespaces
write-host "`tLets modify the WMI permissions to CIMV2 for Nagios!"
$WMISDDL = "A;CI;CCWP;;;$sid"
#PartialMatch
$WMISDDLPartialMatch = "A;\w*;\w+;;;$sid"
# Convert the current permissions to SDDL
$CurrentWMISDDL = $converter.BinarySDToSDDL($binarySD[0])
# Build the new permissions
if (($CurrentWMISDDL.SDDL -match $WMISDDLPartialMatch) -and ($CurrentWMISDDL.SDDL -notmatch $WMISDDL))
$NewWMISDDL = $CurrentWMISDDL.SDDL -replace $WMISDDLPartialMatch, $WMISDDL
else
$NewWMISDDL = $CurrentWMISDDL.SDDL += "(" + $WMISDDL + ")"
# Convert SDDL back to Binary
write-host `t"Converting SDDL back to binary"
$WMIbinarySD = $converter.SDDLToBinarySD($NewWMISDDL)
if ($CurrentWMISDDL.SDDL -match $WMISDDL)
write-host "`t`tCurrent WMI Permissions match desired values."
else
if($result='0'){write-host "`t`tApplied WMI Security complete."}
# add perf counter group membership in local users of the domain account
$LocalGroups = "Performance Monitor Users"
# Simply add groups to the above string comma-seperated and you are legit.
# Again you are using the netbios domain name here... and the domain account for the rights on teh local group for perf mon rights
$LocalGroups | %{Set-UserLocalGroup -Computer $strcomputer -Group $_ -Domain "SUBDOMAIN" -User "NagiosXI" -add} # insert netbios DOMAIN name and user account.
#EOF
# Sonny McManigle - [email protected]
##I'll get this up on the exchange sooner or later, maybe wait a bit for feedback from any of you.
sreinhardt
Fantastic, thank you and sonny! I'm going to take a look, and give it a spin!
