Getting same error when change the password. I am using below command to manually run the check_sharepoint.pl pulgin. Please suggest me on the same.
./check_sharepoint.pl -H example.com -u "xyz\admin" -p AbcdPqr@@ -l '/default.aspx' -s 'Staff' -t 15 -http
CRITICAL: Authentication failed for account 'xyz\admin'
Imran Khan.
Password with exclamation sign (!) in command is not working
imran_khan
Re: Password with exclamation sign (!) in command is not wor
Have you tried encasing the password definition in quotes? That is suggested by the creator of this plugin:
http://exchange.nagios.org/directory/Pl ... pl/details
Notes:
- If you use special characters in your usernames and/or passwords, authentication will
have a better chance of working if you enclose them in quotes.
