Auto-Discovery jobs stalls
Re: Auto-Discovery jobs stalls
I ran the 3 commands you presented and here's the output attached.
Okay lets start with this:
Then try the upload again.
chown nagios:nagios /usr/local/nagiosxi/html/includes/components/autodiscovery/*Re: Auto-Discovery jobs stalls
After I ran the command I went to Nagios console and after login I got:
NSP: Sorry Dave, I can't let you do that
I was able to get into the console successfully before this command run.
Can you follow these steps and let us know if it resolves your sorry dave issue:
http://support.nagios.com/wiki/index.ph ... .22_Errors
Did you try logging out and back in?
My issue is resolved. I waited over night and the Dave issue resolved on its own. Then I imported the zip component and I am able to auto-discover servers. Thank you so much.
Awesome, closing this thread up!
