SNMP Notifications not sent
aap
Re: SNMP Notifications not sent
Post by aap »
Thanks for your reply.
I changed the files to lowercase whilst in the import folder and ran the (/usr/local/nagiosxi/scripts/reconfigure_nagios.sh) script. However, the same behaviour re-occured - the hostname reverted to uppercase. The only way I got the name to remain lowercase was to use the 'Import Config Files' tool in CCM. This renamed the hostname successfully however we lose all historical data for this host - the graphing tool no longer shows old data.
My question now is this - is it possible to actually rename hosts to lowercase without losing historical data?
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Yes and no, the biggest issue I can see for data loss would be historical reporting from logs not rrds. To get graphing back as well, you would just need to rename the rrd files to be lower case as well. This will cause all new data to go right back into them and display all previous data.
aap
Post by aap »
Okay. Thanks. I will do that and let you know how I get on.
Post by slansing »
Great, we will await your reply.
aap
Post by aap »
The deed has been done. Here's how we did it...
We bulk renamed all the hosts using powershell, deleted the current hosts and reimported the now host config files using the import tool.
We then stopped Nagios, and ran the command
for i in *; do mv "$i" "$(echo $i|tr A-Z a-z)"; done
on the perfdata folder. Applied configuration and after about 20 minutes of nail biting, the hosts all re-appeared with the correct data. Looks good so far.
Thanks for all your help.
Post by slansing »
Sounds good, let us know if any issues pop up, I'd give it bit before we know for sure.
