Switch wizard adding everything except entry in mrtg.cfg
snapon_admin
Re: Switch wizard adding everything except entry in mrtg.cfg
Post by snapon_admin »
No, not about this particular host. I get a couple of warnings about 2 hosts that are no longer in Nagios, but that's just because I haven't removed them from the mrtg.cfg file yet.
Edit: For good measure I removed those 2 hosts that no longer exist anyway, and now I get no errors or warnings when I run that command.
sreinhardt
-fno-stack-protector
Post by sreinhardt »
At it again are we? :P Since your permissions look fine on the mrtg.conf file, what are the permissions on the directory?
ll -d /etc/mrtg
snapon_admin
Haha, yep. This time is final though. I told the other net admin if we go back to mrtg we're staying there, lol. So now I just need to make it work and we'll be good.
[root@lisl-ngos-01-pv mrtg]# ll -d /etc/mrtg
drwxrwxr-x. 4 apache nagios 4096 Feb 28 12:32 /etc/mrtg
sreinhardt
Do you have selinux enabled? My guess is no, but that period at the end of your command says that the folder here has extended context permissions set for that folder at the very least, which could cause issues.
ll -Zd /etc/mrtg
ll -Z /etc/mrtg
snapon_admin
[root@lisl-ngos-01-pv mrtg]# ll -Zd /etc/mrtg
drwxrwxr-x. apache nagios system_u:object_r:mrtg_etc_t:s0  /etc/mrtg
[root@lisl-ngos-01-pv mrtg]# ll -Z /etc/mrtg
drwxrwxr-x. apache nagios unconfined_u:object_r:mrtg_etc_t:s0 bkp_cfg
drwxrwxr-x. apache nagios unconfined_u:object_r:mrtg_etc_t:s0 conf.d
-rwxrwxr-x. apache nagios unconfined_u:object_r:mrtg_etc_t:s0 mrtg.bkp
-rwxrwxr-x. apache nagios system_u:object_r:mrtg_etc_t:s0  mrtg.cfg
-rwxrwxr-x. apache nagios unconfined_u:object_r:mrtg_etc_t:s0 mrtg.cfg.bkp
-rwxrwxr-x. apache nagios unconfined_u:object_r:mrtg_etc_t:s0 mrtg.cfg_l_16654
-rwxrwxr-x. apache nagios unconfined_u:object_r:mrtg_etc_t:s0 mrtg.ok
-rwxrwxr-x. apache nagios system_u:object_r:mrtg_etc_t:s0  router.cfg
-rwxrwxr-x. apache nagios system_u:object_r:mrtg_etc_t:s0  router.ok
-rwxrwxr-x. apache nagios unconfined_u:object_r:mrtg_etc_t:s0 separate_mrtg_cfgs
And remember I'm still learning on the fly with linux, but I learn fast. I think this is how to check if selinux is enabled, and it looks like yes?
[root@lisl-ngos-01-pv mrtg]# sestatus
SELinux status:                 enabled
SELinuxfs mount:                /selinux
Current mode:                   permissive
Mode from config file:          permissive
Policy version:                 24
Policy from config file:        targeted
sreinhardt
OK, permissive is good at least it should be allowing everything, even items that would be denied if it was fully enforcing. Are you seeing any errors in the audit log around the time you run the wizard? No worries on the learning, everyone has to start there at some point!
grep -R- 'mrtg' /var/log/audit/audit.log
snapon_admin
Is 'grep -R-' a valid option? Never seen -R- and it didn't seem to like that option. I tried that command with grep -R and got the attached results.
Post by slansing »
I am a bit curious, if you add another device via the wizard, say.. a windows box even, do you get valid bandwidth data back? Can you test a port failure scenario with this switch to see if Nagios properly picks that up? It sounds like this is mainly a bandwidth issue, just hoping that it is restricted to that and not something entirely different. Also, silly question, but you do know for a fact that there is traffic on those interfaces correct?
snapon_admin
Yes, I just added a switch and got bandwidth data back within 5 minutes
Not really. These are our managed MPLS routers. Our carrier manages them, we only have read access to the routers, and there's really no ports we can shut down to test a failed port scenario.
Yes, I can see traffic on the CLI for the router, just not in Nagios.
Post by slansing »
Hmm, this should be fixed in 2012 r2.9, but changes would have to be made to the current mrtg configurations, in your original mrtg.cfg, does it have a line specifying something along the lines of:
include: /etc/mrtg/mrtg.cfg.bkp
If the switch you added was assigned to a different MRTG.cfg file, the fastest way to resolve this would be to include that config file in the original mrtg.cfg file, so it reads both in.
