Custom Quick Actions
Re: Custom Quick Actions
I will be testing this as soon as developers finish the task. I am not sure when they are going to get to it, since this is not a priority at the moment. In any case, we will post the results.
BanditBBS
Post by BanditBBS »
I just tested and this worked:
    786 if(is_admin() == true) {
    787                 // additional actions...
    788                 $cbdata=array(
    789                         "hostname" => $hostname,
    790                         "servicename" => $servicename,
    791                         "service_id" => $service_id,
    792                         "servicestatus_xml" => $xml,
    793                         "actions" => array(),
    794                         );
    795                 do_callbacks(CALLBACK_SERVICE_DETAIL_ACTION_LINK,$cbdata);
    796                 $customactions=grab_array_var($cbdata,"actions",array());
    797                 foreach($customactions as $ca){
    798                         $output.=$ca;
    799                         }
    800                 //$output.=serialize($customactions);
    801
    802                 }
    803                 }
this hides all custom actions on services from non admins. Verified and tested :)
Do the same to the hosts file and it'll work there.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Sweet, thanks for the test!
WillemDH
Post by WillemDH »
Just wanted to inquire to the state of this feature request to enable us to set view permissions per task. We have some actions that need to be visible by normal users, and other that may only be seen by admins.
Tx
Nagios XI 5.8.1
https://outsideit.net
ssax
Dreams In Code
Post by ssax »
He did leave this comment on the feature request, will that not work for you?
I'm going to see about getting this added but just so you guys are aware, you can add the following into the Code box, it will only show for Admins
if(is_admin()){$showlink=true;} else{$showlink=false;}
WillemDH
Post by WillemDH »
Sean,
Sorry I thought I read in the thread:
So I was thinking this only works for all actions or none. I will try your suggestion.
EDIT: I tried:
/*if((%objecttype%=='host' && '%hoststateid%'!='0') || (%objecttype%=='service' && '%servicestateid%'!='0')){$img='/nagiosxi/images/schedulecheck.png';$showlink=true;} else{$showlink=false;}if(is_admin()){$showlink=true;} else{$showlink=false;}*/
/*if((%objecttype%=='host' && '%hoststateid%'!='0') || (%objecttype%=='service' && '%servicestateid%'!='0')){$img='/nagiosxi/images/schedulecheck.png';$showlink=true;} else{$showlink=false;};if(is_admin()){$showlink=true;} else{$showlink=false;}*/
/*if(is_admin()){$showlink=true;} else{$showlink=false;}*/
But the link to the Reactor chain keeps showing for my test normal user. Am I missing something?
EDIT: Never mind, it was actually just
My PHP knowledge is very low. Sorry for that. You can close this thread. This solution is perfect for now. :)
Grtz
Nagios XI 5.8.1
