NCPA not updating config
Re: NCPA not updating config
Any word from the "genius" yet?lmiltchev wrote:I will wait for Nick, the genius, to "enlighten" me on NRDS integration... then we will be updating the documentation, I guess...
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Yep, he said he will be working on it today.Any word from the "genius" yet?
I was right about the fact that you needed to set "handlers = nrds". What I didn't know is that you *should* be able to just add it, so that you would have:
handlers = nrdp
handlers = nrdsCode: Select all
NoOptionError: No option 'TOKEN' in section: 'nrds'Code: Select all
ERROR:root:ConfigParser instance has no attribute 'file_path'
Traceback (most recent call last):
File "C:\Users\nscott\Documents\Git\ncpa\agent\ncpa_windows.py", line 129, in run_all_handlers
File "C:\Program Files (x86)\Nagios\NCPA\passive\nrds.py", line 23, in run
self.update_config()
File "C:\Program Files (x86)\Nagios\NCPA\passive\nrds.py", line 73, in update_config
with open(self.config.file_path , 'w') as config:
AttributeError: ConfigParser instance has no attribute 'file_path'Be sure to check out our Knowledgebase for helpful articles and solutions!
Ok, I have to make some decisions here on how I am going to proceed and need to tell people how things currently function(not how they will)....so with that being said, if I want to use passive checks and control them centrally I have to use NRDS_Win at this moment in time, correct? If I don't care about central administration I can then use NCPA.
Thanks!
edit: OMG my head hurts, I'm really trying to wrap my head around this and think of the best way to monitor my Windows environment. I'm going to open a new thread with a very specific question that isn't directly related to the topic of this thread
Thanks!
That's correct. Sorry for the confusion.BanditBBS wrote:Ok, I have to make some decisions here on how I am going to proceed and need to tell people how things currently function(not how they will)....so with that being said, if I want to use passive checks and control them centrally I have to use NRDS_Win at this moment in time, correct? If I don't care about central administration I can then use NCPA.
Thanks!
