Monitoring IPCop via nrpe
mkot
Re: Monitoring IPCop via nrpe
Post by mkot »
Hmm, at Nagios I've got status information:
(Return code of 255 is out of bounds)
but when I do sth lik this:
 ssh root@<IP_Remote_Linux_Host> /usr/local/nagios/libexec/check_disk -w 20% -c 10% -p /
and I get:
DISK OK - free space: / 32975 MB (74% inode=96%);| /=11574MB;37546;42239;0;46933
EDIT:
infos from remote linux server:
root@domena-wa:~# /usr/local/nagios/libexec/check_nrpe -H localhost
connect to address ::1 port 5666: Connection refused
CHECK_NRPE: Error - Could not complete SSL handshake.
root@domena-wa:~# /usr/local/nagios/libexec/check_nrpe -H <IP_Nagios_Server>
NRPE v2.15
EDIT2:
Is my command definition is correct?
        command_name    check_nrpe
        command_line    $USER1$/check_nrpe -H $HOSTADDRESS$ -c $ARG1$ -t 20
Now I'm getting error
mkot
Post by mkot »
OK. I managed to enable active checks for Ubuntu, CentOS servers and it's working :)
Now I need to configure it at FreeBSD server, IPCopr routers. And I need to find solution for hardware raid monitoring (software raid is working fine ;))
EDIT:
I found plugin which can monitor hardware raid via mdstat (perl plugin - attachment, I had to add extension 'txt' to add it here). I configured command:
command[check_raid]=/usr/local/nagios/libexec/check_raid
When I run /usr/local/nagios/libexec/check_raid at monitord host, I get:
OK: dmraid:[pdc_biiebhfff: /dev/sdc(mirror, 931.40 MiB): ok, /dev/sdb(mirror, 931.40 MiB): ok]
but when I run it at Nagios Server ( Re-schedule the next check of this service) I get Status information:
UNKNOWN: dmraid:[Plugin error]
Log from monitored host:
Mar 27 13:39:58 domena-ld nrpe[16159]: Command completed with return code 3 and output: UNKNOWN: dmraid:[Plugin error]
Mar 27 13:39:58 domena-ld nrpe[16159]: Return Code: 3, Output: UNKNOWN: dmraid:[Plugin error]
And log from nagios Server:
Mar 27 13:39:59 nagios nagios: EXTERNAL COMMAND: SCHEDULE_FORCED_SVC_CHECK;domena-ld;RAID Monitoring;1395923997
Mar 27 13:39:59 nagios nagios: SERVICE ALERT: domena-ld;RAID Monitoring;UNKNOWN;SOFT;3;UNKNOWN: dmraid:[Plugin error]
check_raid.txt
(90.64 KiB) Downloaded 474 times
Post by slansing »
Can you show us the service configuration for this check on your nagios server, and also the check command it is using? If at all possible, output of manually running the check via the command line would be great as well.
mkot
Post by mkot »
Hi, this is my command definition in nrpe.cfg file at host:
If I run /usr/local/nagios/libexec/check_raid (at this host) I'll get good informations:
At Nagios server in my linux-wa.cfg file I have service definition:
# Monitorowanie Hardware RAID
        use                     local-service
        host_name               domena-ld
        service_description     RAID Monitoring
        check_command           check_nrpe!check_raid
        notifications_enabled   1
        flap_detection_enabled  0
        active_checks_enabled   1
        passive_checks_enabled  0
It's sth like that (I can't establish VPN connection to my company network, so I can't check it good).
What is the output of the following two commands run on the nagios server (from the plugins directory)?
./check_nrpe -H <client ip>
./check_nrpe -H <client ip> -c check_raid
mkot
Post by mkot »
1.
root@nagios:/usr/local/nagios/libexec# ./check_nrpe -H <ip_host>
NRPE v2.15
2.
root@nagios:/usr/local/nagios/libexec# ./check_nrpe -H 172.17.24.12 -c check_raid
But when I run check_raid at this host I get good values:
Maybe Nagios dont understand it?
Post by slansing »
Can you attach a copy of the nrpe.cfg or /etc/xinetd.d/nrpe file from that host? I'd like to see how you have that command defined.
mkot
Post by mkot »
/etc/xinet.d/nrpe
# default: on
# description: NRPE (Nagios Remote Plugin Executor)
service nrpe
        flags           = REUSE
        socket_type     = stream
        port            = 5666
        wait            = no
        user            = nagios
        group           = nagios
        server          = /usr/local/nagios/bin/nrpe
        server_args     = -c /usr/local/nagios/etc/nrpe.cfg -i
        log_on_failure  += USERID
        disable         = no
        only_from       = <IP_Nagios_Server>,127.0.0.1
log_facility=daemon
pid_file=/var/run/nrpe.pid
server_port=5666
nrpe_user=nagios
nrpe_group=nagios
allowed_hosts=<IP_Nagios_Server>
dont_blame_nrpe=0
allow_bash_command_substitution=0
debug=1
command_timeout=60
connection_timeout=300
command[check_mem]=/usr/local/nagios/libexec/check_mem.pl -w 98 -c 99
command[check_cpu]=/usr/local/nagios/libexec/check_cpu.sh -w 98 -c 99
command[check_/]=/usr/local/nagios/libexec/check_disk -w 1% -c 0% -p /dev/mapper/pdc_dfagcaei1
command[check_/mnt/backup]=/usr/local/nagios/libexec/check_disk -w 1% -c 0% -p /dev/sda1
command[check_/home]=/usr/local/nagios/libexec/check_disk -w 1% -c 0% -p /dev/mapper/pdc_dfagcaei6
command[check_/home/domena/raporty]=/usr/local/nagios/libexec/check_disk -w 1% -c 0% -p /dev/mapper/pdc_jifggjdg6
command[check_/home/domena/wymiana_miedzyoddzial]=/usr/local/nagios/libexec/check_disk -w 1% -c 0% -p /dev/mapper/pdc_jifggjdg5
EDIT:
I don't know if it's important, but at this host (not Nagios Serwer) when I do:
root@domena-wa:/usr/local/nagios/libexec# ./check_nrpe -H localhost
or
root@domena-wa:/usr/local/nagios/libexec# ./check_nrpe -H localhost -c check_raid
I get
Ironically it looks like a firewall issue. Did you open port 5666 on the device throwing that "Connection refused" error?
mkot
Post by mkot »
Yes, I added to /etc/services:
nrpe 5666/tcp
And my iptables is empty (we don't use it).
root@host:~# iptables -L
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Technically if I wouldn't add it, my other checks (check_disk, check_mem.sh, check_cpu.pl) wouldn't work to, but they're working fine ;)
