No, we work almost exclusively with VMs. If you can't just toss away your current install and start fresh then testing anything to see if it works is not something that will easily be backed out of.
I was trained on NT SP2 to click on the box to NOT save the uninstall files, if this upgrade doesn't work those files are going to be useless... aren't they. Now I can pass this lesson on to you.
