Is there any notable difference in configuration on that one server which is throwing errors? Anything you might have changed on a filesystem level, maybe some changed PHP settings, an edit to the nagios.cfg file?andre.roberge wrote:No they are all at different sites with different subnet.
Some are on normal internet some are on satellite link.
Andre
Unable to retrieve data from the local cache.
Re: Unable to retrieve data from the local cache.
On the "problematic" Nagios XI server, run the following command and show us the output:
ping <nagios fusion server's ip> -c 5Be sure to check out our Knowledgebase for helpful articles and solutions!
Solved in a remote, incorrectly defined server address.
