check_apc.pl help
Re: check_apc.pl help
brandon.pal wrote:OK. THank you. I assume the numbers I listed from SNMPWALK are the OID's I can use but how do I find out what is what? I need to figure out voltage, ups state and health from those numbers...?
That's a little harder. If you can log into the device and query it directly, you could compare the OID values with what you query. Otherwise look for documentation on the device. Or find the MIB.
