CRITICAL: No DHCPOFFERs were received.
Re: CRITICAL: No DHCPOFFERs were received.
Lo siento, pero debemos hablar en inglés. Yo he enviado un PM.
I am sorry, but we must speak in English. I have sent a PM.
I am seeing this same behavior. When I run
./check_dhcp -v
I do not receive any results. I will speak with the plugin developers about this.
eloyd
Cool Title Here
Post by eloyd »
Pero, quien a pensar de los niños? 8-)
I'll worry about the users, someone else can take care of the kids.
sblain
Post by sblain »
Hi, ok i'll speak in english, but it's not well
Any suggest for my problem?? nagios doesn't check the dhcp server on localhost ....i've done all and don't get any result sucessfully...
sorry my english...
Post by Box293 »
You'll need to tell us the output from these suggestions.
lmiltchev wrote:Are you sure that localhost is your dhcp server? Try testing it with dhcping:
dhcping -s <server ip> -c <client ip>
When I test our dhcp server, I get:
[root@localhost ~]# dhcping -s 192.168.x.x -c 192.168.x.x
Got answer from: 192.168.x.x
but when I test it against localhost (it's not a dhcp server), I get "no answer"):
[root@localhost ~]# dhcping -s 127.0.0.1 -c 192.168.x.x
no answer
If you don't have dhcping installed, you can install it by running:
yum install dhcping -y
You can try some other tools for debugging, such as dhcpdump.
tmcdonald wrote:Also, are you certain that DHCP is even running?
service dhcpd status
