nagios db issue
Re: nagios db issue
Attached output.
Re: nagios db issue
Well, you have some interesting issues with shared libraries. Have you upgraded or installed any packages or libraries by hand?
What is the output of:
yum list installed | grep mysql
uname -aFormer Nagios employee
Re: nagios db issue
Attached output.
As you were aware of last install which you did along with us.You suggested follow below process and we followed same.
Just to recap. After you install a fresh server, you need to remove the following by way of:
rpm -e --nodeps mysql-libs
yum remove mysql mysql-server
And then run the XI install. If you have further issues, let me know.
Apart from that we did not install any packages/libraries.We consulted you through this as soon as we got error.
Re: nagios db issue
What is the output of:IOError: [Errno 28] No space left on device
df -i
df -h
Re: nagios db issue
We cleared some files and lot of space left.
tmproot@usa7061lv1152>df -k
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/mapper/VolGroup00-LogVol00 16513960 9858012 5817088 63% /
tmpfs 2097152 0 2097152 0% /dev/shm
/dev/sda1 516040 68892 420936 15% /boot
/dev/mapper/VolGroup00-LogVol03 8256952 1919372 5918152 25% /tmp
/dev/mapper/VolGroup00-LogVol01 8256952 2245300 5592224 29% /var
/dev/mapper/VolGroupU01-LogVolU01 185778164 16965780 159375408 10% /u01
/tmp/UNIX7.1.iso 1367202 1367202 0 100% /tmp/netiq
usa7061av4575:/HOME_DIR/w3vlm5yc 51628800 257440 51371360 1% /home/w3vlm5yc
usa7061av4575:/HOME_DIR/w3tt47zq 51628800 257440 51371360 1% /home/w3tt47zq
usa7061av4575:/HOME_DIR/q3q72rdq 51628800 257440 51371360 1% /home/q3q72rdq
tmproot@usa7061lv1152>df -h
/dev/mapper/VolGroup00-LogVol00 16G 9.5G 5.6G 63% /
tmpfs 2.0G 0 2.0G 0% /dev/shm
/dev/sda1 504M 68M 412M 15% /boot
/dev/mapper/VolGroup00-LogVol03 7.9G 1.9G 5.7G 25% /tmp
/dev/mapper/VolGroup00-LogVol01 7.9G 2.2G 5.4G 29% /var
/dev/mapper/VolGroupU01-LogVolU01 178G 17G 152G 10% /u01
/tmp/UNIX7.1.iso 1.4G 1.4G 0 100% /tmp/netiq
usa7061av4575:/HOME_DIR/w3vlm5yc 50G 252M 49G 1% /home/w3vlm5yc
usa7061av4575:/HOME_DIR/w3tt47zq 50G 252M 49G 1% /home/w3tt47zq
usa7061av4575:/HOME_DIR/q3q72rdq 50G 252M 49G 1% /home/q3q72rdq
I ran the command again and here is the output.
tmproot@usa7061lv1152>yum list installed | grep mysql
This system is not registered to Red Hat Subscription Management. You can use subscription-manager to register.
mysql.x86_64 5.1.73-3.el6_5 @rhel-x86_64-server-6
mysql-devel.x86_64 5.1.73-3.el6_5 @rhel-x86_64-server-6
mysql-libs.x86_64 5.1.73-3.el6_5 @rhel-x86_64-server-6
mysql-server.x86_64 5.1.73-3.el6_5 @rhel-x86_64-server-6
php-mysql.x86_64 5.3.3-27.el6_5 @rhel-x86_64-server-6
Can we have webex today to solve this.We have production launch on saturday and we need to get this fixed asap.
