Having Some NRPE issues with specific commands
abrist
Red Shirt
Re: Having Some NRPE issues with specific commands
Post by abrist »
Try:
su - -s /bin/bash nagios '/usr/lib64/nagios/plugins/check_open_files.pl -w 85 -c 95'
echo $?
Or:
su - nagios -c "/usr/lib64/nagios/plugins/check_open_files.pl -w 85 -c 95"
echo $?
brandon.pal
Post by brandon.pal »
[root@dc01-cache-01 plugins]# ./check_open_files.pl -w 85 -c 95
OK: 928 open files (0% of max 1000000)|opened_files=928;850000;950000
[root@dc01-cache-01 plugins]# su - -s /bin/bash nagios /usr/lib64/nagios/plugins/check_open_files.pl -w 85 -c 95
su: invalid option -- 'w'
Try `su --help' for more information.
 su -l -s /bin/bash nagios /usr/lib64/nagios/plugins/check_open_files.pl
/usr/lib64/nagios/plugins/check_open_files.pl: line 3: use: command not found
/usr/lib64/nagios/plugins/check_open_files.pl: line 4: syntax error near unexpected token `('
/usr/lib64/nagios/plugins/check_open_files.pl: line 4: `use vars qw($opt_h $PROGNAME $opt_w $opt_c $opt_t $opt_vi $msg $state);'
abrist
Red Shirt
Post by abrist »
Can nagios see the perl bin and use it?
su -l -s /bin/bash nagios -c "which perl"
su -l -s /bin/bash nagios -c "perl --version"
brandon.pal
[root@dc01-cache-01 ~]# su -l -s /bin/bash nagios -c "which perl"
/usr/bin/perl
[root@dc01-cache-01 ~]# su -l -s /bin/bash nagios -c "perl --version"
This is perl, v5.10.1 (*) built for x86_64-linux-thread-multi
Copyright 1987-2009, Larry Wall
Perl may be copied only under the terms of either the Artistic License or the
GNU General Public License, which may be found in the Perl 5 source kit.
Complete documentation for Perl, including FAQ lists, should be found on
this system using "man perl" or "perldoc perl".  If you have access to the
Internet, point your browser at http://www.perl.org/, the Perl Home Page.
Run the following commands and show the output.
usermod -s /bin/bash nagios
su nagios
echo $?
brandon.pal
[root@dc01-cache-01 ~]# usermod -s /bin/bash nagios
[root@dc01-cache-01 ~]# su nagios
bash-4.1$ /usr/lib64/nagios/plugins/check_open_files.pl -w 85 -c 95
Can't locate utils.pm in @INC (@INC contains: /usr/local/nagios/libexec /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at /usr/lib64/nagios/plugins/check_open_files.pl line 6.
BEGIN failed--compilation aborted at /usr/lib64/nagios/plugins/check_open_files.pl line 6.
bash-4.1$ echo
Post by slansing »
Did you compile the nagios plugins package on this system? It looks like you are missing the Utils perl module. Can you attach your plugin? I'd be interested in seeing it's USE definition, since you have a fairly unstandard directory for your plugins I would not be surprised if it is looking in the wrong location. Does the file "utils.pm" exist in your plugin directory?
brandon.pal
From what I know our prod sys admin did this:
rpm -Uvh http://dl.fedoraproject.org/pub/epel/6/x86_64/epel-release-6-8.noarch.rpm
rpm -Uvh http://rpms.famillecollet.com/enterprise/remi-release-6.rpm
yum -y install nagios nagios-plugins-all nrpe
chkconfig nagios on
slansing wrote:Does the file "utils.pm" exist in your plugin directory?
/usr/lib64/nagios/plugins/utils.pm
slansing wrote:I'd be interested in seeing it's USE definition
use Getopt::Long;
 use lib "/usr/local/nagios/libexec";
use utils qw(%ERRORS &print_revision &support &usage );
Post by slansing »
Try changing:
To
use lib "/usr/lib64/nagios/plugins/";
Then run the commands lmiltchev posted above, again, thanks!
Yeah yum is a really easy way to install applications, unfortunately on a system to system basis and package to package, the directory structure or contents of the package can change. That's why I usually recommend compiling the plugins by hand.
brandon.pal
brandon.pal wrote:Then run the commands lmiltchev posted above, again, thanks!
OK: 1408 open files (0% of max 1000000)|opened_files=1408;850000;950000
bash-4.1$ echo $?
0
brandon.pal wrote:That's why I usually recommend compiling the plugins by hand.
I'll be honest. I have no idea how to do that.
