Adding servers problem
This support forum board is for questions relating to Nagios Fusion.
alepo.prateek
Re: Adding servers problem
Post by alepo.prateek »
Hi Team,
Many thanks for your reply. Please find the below requested output :
[root@localhost subsys]# ls -la /usr/local/nagiosfusion/var
total 24
drwxr-xr-x 5 icingaadmin nagios 4096 Dec 19 10:15 .
drwxr-xr-x 8 icingaadmin nagios 4096 Dec 18 11:27 ..
drwsrwsr-x 2 apache nagios 4096 Dec 18 11:27 components
-rwxr-xr-x 1 icingaadmin nagios 206 Dec 18 11:38 fusionversion
drwxr-xr-x 2 icingaadmin nagios 4096 Dec 18 11:27 subsys
drwxr-xr-x 2 icingaadmin nagios 4096 Dec 18 11:27 upgrades
[root@localhost subsys]# chage -l nagios
Last password change : Dec 18, 2014
Password expires : never
Password inactive : never
Account expires : never
Minimum number of days between password change : 0
Maximum number of days between password change : 99999
Number of days of warning before password expires : 7
It has been a quite long since i am stuck. Awaiting for your earliest feedback.
alepo.prateek
HI Nagios Team,
I have resolved the problem of php unserialize handling.
Now i am able to add a new server , however after adding the servers , i am getting the error as shown in attached screenshot.
I am able to wget the specified URL from the server as well as directly from interface. Please let me know the way forward .
Also ,for your information , please confirm that nagios fusion will also work if multiple client instances are from icinga. If not , please specify another aggregator.
lgroschen
Post by lgroschen »
We don't specifically support Icinga for Nagios Fusion, but you can always try changing the server type to nagios so Icinga thinks its a core server. Nagios XI as a server type in Fusion passes a lot of things exclusive to XI.
/Luke
alepo.prateek
Hi Nagios Team,
Now, while clicking on HOME -> Tactical Overview i am getting the error as "Unable to retrieve data from the local cache."
PFA the screenshot .
Do help me out in getting the above issue fixed. I have checked the code and found that one entry has got inserted into table fusion_tac_data but with no values.
Prateek Agarwal
Post by slansing »
Unfortunately, as you have been told, we do not support Icinga. Nagios Fusion is meant for use with true Nagios Enterprises solutions such as Core, and XI. If you would like to resume working with Fusion, with one of those tools, feel free to open a new thread.
