The version sreinhardt linked is actually the old version as it was doing a >= check for warning/critical instead of the intended <= .
Here is the correct version of the wizard with the correct plugin. Give it a try and let us know how it goes!
Hope this solves everything for you, and I appreciate the feedback!
/Luke
Couple of post migration issues
Re: Couple of post migration issues
/Luke
Thank you, Luke. The one you've linked is working correctly! I've got both of our domains in there now, I've played around with the warn and crit values to make sure the alerts get triggered. Everything seems to be fine. Both problems I originally created this thread for have now been resolved, this topic can be locked. Thank you to all the Nagios guys for your support.
