Upgraded to 2014R1.0: 'Network Outages' Unable to parse XML
Re: Upgraded to 2014R1.0: 'Network Outages' Unable to parse
/usr/local/nagios/bin/ndo2db | head -2
NDO2DB 1.5.2
I do indeed have check_mk (ver 1.2.2p3) running.
If that is an issue is there a specific method for removing it?
NDO2DB 1.5.2
You can just comment out the lines, that refer to mk-livestatus in the nagios.cfg file and restart nagios. The problem is that the nagios service won't start as ndo2db didn't get upgraded for some reason (possibly config errors or "ghost" hosts/services).I do indeed have check_mk (ver 1.2.2p3) running.
Go to: CCM->Tools->Write Config Files->Click on "Write" and "Verify" buttons and examine the output for errors. If you have config errors (warnings are OK), go back to CCM and fix them, then run the "Write Config Tool" again to check for more errors. Run the "Write Config Tool" as many times as you have to, until ALL of the config errors are gone. Then Apply Configuration. Go to the original install directory, and re-run the upgrade script:
cd /tmp/nagiosxi
./upgradeCode: Select all
/usr/local/nagios/bin/ndo2db | head -2Code: Select all
NDO2DB 2.0.0Be sure to check out our Knowledgebase for helpful articles and solutions!
I get only warnings, for alleged "Duplicate definition" issues, that is all.
I have learned that when I have several similar named hosts that have the same service check names NagiosXI gives me these duplicate problems.
Nothing to fix then.?.
It ends with "No serious problems were detected during the pre-flight check "
This seems to be a dead end.
What is the ndo2db version?
Did you have any mk-livestatus entries in the nagios.cfg? Are they commented out?
/usr/local/nagios/bin/ndo2db | head -2Be sure to check out our Knowledgebase for helpful articles and solutions!
Downloaded the -2014r1.1 version.
Commented out these 2 lines at end of nagios.cfg:
###use_true_regexp_matching=0# Load Livestatus Module
###broker_module=/usr/lib/check_mk/livestatus.o /opt/nagios/var/rw/live
Ran upgrade, all looked good.
At end:
> ndodb was: NDO2DB 2.0.0
> 'System Status ' was all green
> 'Monitoring Engine Status' showed not started
> Selecting 'Start' for 'Monitoring Engine' would show Success but it would not start.
At end:
sreinhardt
- -fno-stack-protector
The web interface may be having trouble picking up the lock file. Let's make sure it is running and see what permissions are in place.
service nagios status
ps -ef | grep bin/nag
ll /usr/local/nagios/var/nagios.lock
cat /usr/local/nagios/var/nagios.lockNagios-Plugins maintainer exclusively, unless you have other C language bugs with open-source nagios projects, then I am happy to help! Please pm or use other communication to alert me to issues as I no longer track the forum.
Cleared /tmp then ran upgrade again, after upgrade:
$ ps -ef | grep bin/nag
$ ll /usr/local/nagios/var/nagios.lock
-rw-r--r-- 1 nagios nagios 6 Jun 10 06:38 /usr/local/nagios/var/nagios.lock
$ cat /usr/local/nagios/var/nagios.lock
14797
Could not start from command line either.
Went to "Write Config Files" and did a verify, all looks fine:
Nagios Core 4.0.6
Last Modified: 04-29-2014
License: GPL
Reading configuration data...
Read main config file okay...
Warning: failure_prediction_enabled is obsoleted and no longer has any effect in host type objects (config file '/usr/local/nagios/etc/static/check_mk_templates.cfg', starting at line 88)
Warning: failure_prediction_enabled is obsoleted and no longer has any effect in service type objects (config file '/usr/local/nagios/etc/static/check_mk_templates.cfg', starting at line 157)
Checking objects...
Checked 436 services.
Checked 63 hosts.
Checked 14 host groups.
Checked 5 service groups.
Checked 13 contacts.
Checked 3 contact groups.
Checked 125 commands.
Checked 18 time periods.
Checked 0 host escalations.
Checked 63 hosts
Checked 0 host dependencies
Checked 18 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
14797
Nagios Core 4.0.6
License: GPL
Checking objects...
Checked 63 hosts.
Checked 63 hosts
Total Warnings: 0
Total Errors: 0
If nagios is not running, there should be no lock file. Make sure nagios is stopped, kill any potential instances, delete the lock file, and then restart nagios. If you get any errors, post them here.
service nagios stop
killall nagios
ps -aef | grep nagios.cfg
rm /usr/local/nagios/var/nagios.lock
service nagios startFormer Nagios employee
service nagios stop
Stopping nagios: /etc/init.d/nagios: line 67: kill: (32016) - No such process
done.
killall nagios
nagios: no process killed
myid 307 24147 0 11:38 pts/0 00:00:00 grep nagios.cfg
cat: /usr/local/nagios/var/nagios.lock: No such file or directory
Starting nagios: done.
584
NOTE: The lock file is generated every time Nagios tries to start.
It is not cleaned up when the start fails.
done.
killall nagios
584
Run the following commands and show us the output:
tail -50 /var/log/messages
tail -50 /usr/local/nagios/var/nagios.logBe sure to check out our Knowledgebase for helpful articles and solutions!
