Some performance graphs not working after upgrade
btemple
Re: Some performance graphs not working after upgrade
Post by btemple »
Here is a look at the actual files they consistently quit updating after the upgrade. I use the same check for cpu memory and temperature with a unique oid
abrist
Red Shirt
Post by abrist »
Schedule an immediate check for one of the broken services and then post new tails for the logs:
tail -50 /usr/local/nagios/var/npcd.log
tail -50 /usr/local/nagios/var/perfdata.log
btemple
Post by btemple »
It appears I do not have a perfdata.log on this system. Attached is the results of the other log
The bottom graph from this post
http://support.nagios.com/forum/viewtop ... 26#p100118
now shows
Performance Data: =40C;100;120;
As Box293 pointed out
This is the expected format:
    'label'=value[UOM];[warn];[crit];[min];[max]
There should be something to the left of the =
This is the label and is required.
btemple
Post by btemple »
Like this ?
That looks correct.
btemple
Post by btemple »
That was it thanks !
