False packet loss in graphs
David.adder
Re: False packet loss in graphs
Post by David.adder »
I don't know why but I am not able to see the version of the plugin via command:
Regarding language:
Definitely something odd going on. Can we grep for the version?
strings /usr/local/nagios/libexec/check_icmp | grep "^2\."
David.adder
Still not result get...
Run the following and attach the /tmp/check_icmp.txt file that is created:
base64 /usr/local/nagios/libexec/check_icmp > /tmp/check_icmp.txt
David.adder
Yo can find it attached
check_icmp.txt
Looks like you are running v1.4.13 which is a bit older (current that I have is v2.0.2).
Make a copy of your current check_icmp and store it in /tmp, then use the newer one I have attached to *manually* try running the check and see if it works better.
Post the output so we can see if the perfdata will be changed at all. If not, we can use it as a drop-in replacement.
David.adder
I did it. I seemed to work fine, as typing command I don't get packet loss.
But now I have this problem...
That date and file size makes me think the plugin was not replaced. Can you run that version of check_icmp with the -V flag to make sure it is the right version?
David.adder
I already replaced... but I did rollback because of this problem I am getting now. I tried to used the old pluging for this, but problems persists...
Well you do need to use the new plugin otherwise I can't troubleshoot it. Make sure you are running the new plugin and then run the commands that were specified in your XI screenshot:
chown root.root /usr/local/nagios/libexec/check_icmp
chmod u+s /usr/local/nagios/libexec/check_icmp
