Host checks not changing even when system down.
Re: Host checks not changing even when system down.
Did you by any chance censor the IP addresses in that file? All of the host addresses are like "xxx.xxx.xxx.12".
EchoKev
Post by EchoKev »
That is correct.
In your nagios.cfg is the following set?
execute_host_checks=1
EchoKev
Post by EchoKev »
scottwilkerson wrote:In your nagios.cfg is the following set?
Yes it is
# HOST CHECK EXECUTION OPTION
# This determines whether or not Nagios will actively execute
# host checks when it initially starts.  If this option is
# disabled, checks are not actively made, but Nagios can still
# receive and process passive check results that come in.  Unless
# you're implementing redundant hosts or have a special need for
# disabling the execution of host checks, leave this enabled!
# Values: 1 = enable checks, 0 = disable checks
What specific host is this occurring for?
EchoKev
Post by EchoKev »
tmcdonald wrote:What specific host is this occurring for?
Pretty much all of them.
Would it be possible for you to share your nagios.cfg?
Also, if you go to "Process Info" in the UI, you do have the following correct?
Host Checks Being Executed?	YES
EchoKev
Post by EchoKev »
See attached.
nagios.cfg
(44.75 KiB) Downloaded 392 times
Do you mean all or pretty much all hosts? Because if it is pretty much all there might be a pattern.
And we might want to enable some really verbose debugging and run nagios for a bit:
service nagios stop
<edit debug_level to be 16 in nagios.cfg>
service nagios start
Let it run for 60 seconds, then stop it again, turn debugging back to 0, and send us your /usr/local/nagios/var/nagios.debug and /usr/local/nagios/var/nagios.log files. During this time, manually re-schedule a host check in Core.
