snmp traps
hanya.radwan
Re: snmp traps
the results of the commands:
[root@nms ~]# ll /var/spool/snmptt/ | wc -l
205221
You have mail in /var/spool/mail/root
[root@nms ~]#
[root@nms ~]# ll -t /var/spool/snmptt | tail -20
-rw-r--r-- 1 root root 498 Jun 5 10:39 #snmptt-trap-1401953999174897
-rw-r--r-- 1 root root 510 Jun 5 10:39 #snmptt-trap-1401953994078336
-rw-r--r-- 1 root root 510 Jun 5 10:39 #snmptt-trap-1401953991437241
-rw-r--r-- 1 root root 472 Jun 5 10:39 #snmptt-trap-1401953991246641
-rw-r--r-- 1 root root 472 Jun 5 10:39 #snmptt-trap-1401953991046039
-rw-r--r-- 1 root root 473 Jun 5 10:39 #snmptt-trap-1401953990813643
-rw-r--r-- 1 root root 509 Jun 5 10:39 #snmptt-trap-1401953990502630
-rw-r--r-- 1 root root 506 Jun 5 10:39 #snmptt-trap-1401953990222957
-rw-r--r-- 1 root root 510 Jun 5 10:39 #snmptt-trap-1401953990048666
-rw-r--r-- 1 root root 498 Jun 5 10:39 #snmptt-trap-1401953989861861
-rw-r--r-- 1 root root 479 Jun 5 10:39 #snmptt-trap-1401953989637311
-rw-r--r-- 1 root root 482 Jun 5 10:39 #snmptt-trap-1401953989328120
-rw-r--r-- 1 root root 481 Jun 5 10:39 #snmptt-trap-1401953988810795
-rw-r--r-- 1 root root 509 Jun 5 10:39 #snmptt-trap-1401953987910472
-rw-r--r-- 1 root root 512 Jun 5 10:39 #snmptt-trap-1401953987163991
-rw-r--r-- 1 root root 511 Jun 5 10:39 #snmptt-trap-1401953980718218
-rw-r--r-- 1 root root 510 Jun 5 10:39 #snmptt-trap-1401953956252878
-rw-r--r-- 1 root root 509 Jun 5 10:39 #snmptt-trap-1401953948500433
-rw-r--r-- 1 root root 512 Jun 5 10:39 #snmptt-trap-1401953941879753
-rw-r--r-- 1 root root 511 Jun 5 10:38 #snmptt-trap-1401953934572774
205221
[root@nms ~]#
sreinhardt
- -fno-stack-protector
Re: snmp traps
Those permissions are not correct for how our script should set it up, please run the following:
Versions installed
Looking for bins:
snmptt\trapd settings and user perms:
Checking log and spool dirs:
Versions installed
rpm -qa | grep snmpCode: Select all
ls -lva /usr/local/bin | grep -i 'snmp\|addmib'
ls -lva /usr/local/sbin | grep -i 'snmp\|addmib'
ls -lva /usr/sbin | grep -i 'snmp\|addmib'Code: Select all
grep -i 'daemon_uid\|mode =' /etc/snmp/snmptt.ini
grep -i 'exec' /etc/snmp/snmptt.conf | tail -n 10
grep -i 'nag' /etc/group
grep -i 'snmp' /etc/groupCode: Select all
ll /var/log/snmptt/
ll -d /var/log/snmptt/
ll -d /var/spool/snmpttNagios-Plugins maintainer exclusively, unless you have other C language bugs with open-source nagios projects, then I am happy to help! Please pm or use other communication to alert me to issues as I no longer track the forum.
hanya.radwan
Re: snmp traps
Versions installed;
[root@nms ~]# rpm -qa | grep snmp
net-snmp-5.5-49.el6_5.1.x86_64
net-snmp-utils-5.5-49.el6_5.1.x86_64
snmptt-1.3-3.nagios.noarch
php-snmp-5.3.3-27.el6_5.x86_64
net-snmp-libs-5.5-49.el6_5.1.x86_64
net-snmp-perl-5.5-49.el6_5.1.x86_64
Looking for bins:
[root@nms ~]# ls -lva /usr/local/bin | grep -i 'snmp\|addmib'
-rwxr-xr-x 1 root root 879 Jun 13 2013 addmib
-rwxrw-rw- 1 root root 1321 Jul 4 2013 addmib.nms
-rwxr-xr-x 1 root root 804 Jun 13 2013 addmib.orig
-rwxr-xr-x 1 root root 3601 Jul 14 2013 snmptraphandling.py
-rwxr-xr-x 1 root root 3381 Jul 10 2013 snmptraphandling.py.nms
-rwxr-xr-x 1 root root 2078 Jul 10 2013 snmptraphandling.py.orig
-rwxr-xr-x 1 root root 30775 Sep 15 2013 snmpttconvertmib
-rwxr-xr-x 1 root root 30438 Sep 15 2013 snmpttconvertmib.1.3
-rwxr-xr-x 1 root root 30775 Sep 15 2013 snmpttconvertmib.1.4_2beta
[root@nms ~]# ls -lva /usr/local/sbin | grep -i 'snmp\|addmib'
-rwxr-xr-x 1 root root 177466 Sep 15 2013 snmptt
-rwxr-xr-x 1 root root 6488 Nov 1 2012 snmptthandler
-rwxr-xr-x 1 root root 177466 Sep 15 2013 snmptt.1.3
-rwxr-xr-x 1 root root 177466 Sep 15 2013 snmptt.1.4_2beta
[root@nms ~]# ls -lva /usr/sbin | grep -i 'snmp\|addmib'
-rwxr-xr-x 1 root root 30744 Mar 24 20:11 snmpd
-rwxr-xr-x 1 root root 30776 Mar 24 20:11 snmptrapd
[root@nms ~]# grep -i 'daemon_uid\|mode =' /etc/snmp/snmptt.ini
mode = daemon
description_mode = 1
# A second (child) process will be started as the daemon_uid user so
daemon_uid = snmptt
[root@nms ~]# grep -i 'exec' /etc/snmp/snmptt.conf | tail -n 10
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "New device detected $*"
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "Existing controller changed $*"
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "Existing device changed $*"
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "Self-Monitoring Warning (predictive failure - data recovery possible) $*"
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "Self-Monitoring Warning (predictive failure - data recovery questionable) $*"
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "Storage Controller Error (not responding) $*"
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "New Storage controller detected $*"
[root@nms ~]# grep -i 'nag' /etc/group
nagios:x:500:nagios,apache
nagcmd:x:501:nagios,apache
[root@nms ~]# grep -i 'snmp' /etc/group
snmptt:x:496:
[root@nms ~]# ll /var/log/snmptt/
total 9524972
-rw-r--r-- 1 snmptt root 2274963222 Jun 9 22:13 snmptt.debug
-rw-r--r-- 1 snmptt root 17654937 Jun 4 04:42 snmptt.debug-20140604
-rw-r--r-- 1 snmptt root 2618039525 Jun 6 03:09 snmptt.debug-20140606
-rw-r--r-- 1 snmptt root 2598377876 Jun 6 19:27 snmptt.debug-20140607
-rw-r--r-- 1 snmptt root 2108311943 Jun 9 03:33 snmptt.debug-20140609
-rw-r--r-- 1 root root 53147408 Jun 9 22:13 snmptthandler.debug
-rw-r--r-- 1 root root 20923225 Jun 6 03:08 snmptthandler.debug-20140606
-rw-r--r-- 1 root root 60875791 Jun 8 03:50 snmptthandler.debug-20140608
-rw-r--r-- 1 root root 228548 Jun 9 11:08 snmpttsystem.log
-rw-r--r-- 1 root root 80664 Jun 3 15:12 snmpttsystem.log-20140604
-rw-r--r-- 1 root root 793196 Jun 6 18:46 snmpttsystem.log-20140608
[root@nms ~]# ll -d /var/log/snmptt/
drwxr-xr-x 2 root root 4096 Jun 9 03:33 /var/log/snmptt/
[root@nms ~]# ll -d /var/spool/snmptt
drwxrwxrwx 2 root root 12136448 Jun 9 22:20 /var/spool/snmptt
this is part of the result of the following command , it returns trps from 5 jun, 6 jun, 7 jun, 8 jun, 9 june;
-rw-r--r-- 1 root root 509 Jun 9 22:20 #snmptt-trap-1402341635204260
-rw-r--r-- 1 root root 497 Jun 9 22:20 #snmptt-trap-1402341636322016
-rw-r--r-- 1 root root 505 Jun 9 22:20 #snmptt-trap-1402341637940746
-rw-r--r-- 1 root root 480 Jun 9 22:20 #snmptt-trap-1402341638140006
-rw-r--r-- 1 root root 481 Jun 9 22:20 #snmptt-trap-1402341638298798
-rw-r--r-- 1 root root 478 Jun 9 22:20 #snmptt-trap-1402341638401890
-rw-r--r-- 1 root root 509 Jun 9 22:20 #snmptt-trap-1402341640266370
-rw-r--r-- 1 root root 510 Jun 9 22:20 #snmptt-trap-1402341642181099
-rw-r--r-- 1 root root 472 Jun 9 22:20 #snmptt-trap-1402341645913940
-rw-r--r-- 1 root root 473 Jun 9 22:20 #snmptt-trap-1402341651989700
-rw-r--r-- 1 root root 473 Jun 9 22:20 #snmptt-trap-1402341652103313
-rw-r--r-- 1 root root 509 Jun 9 22:20 #snmptt-trap-1402341655081600
-rw-r--r-- 1 root root 476 Jun 9 22:20 #snmptt-trap-1402341656029003
-rw-r--r-- 1 root root 505 Jun 9 22:20 #snmptt-trap-1402341656996502
-rw-r--r-- 1 root root 505 Jun 9 22:20 #snmptt-trap-1402341658531456
-rw-r--r-- 1 root root 497 Jun 9 22:21 #snmptt-trap-1402341660607264
-rw-r--r-- 1 root root 509 Jun 9 22:21 #snmptt-trap-1402341665104472
-rw-r--r-- 1 root root 472 Jun 9 22:21 #snmptt-trap-1402341665922629
-rw-r--r-- 1 root root 481 Jun 9 22:21 #snmptt-trap-1402341666056512
-rw-r--r-- 1 root root 482 Jun 9 22:21 #snmptt-trap-1402341666156010
-rw-r--r-- 1 root root 479 Jun 9 22:21 #snmptt-trap-1402341666362482
-rw-r--r-- 1 root root 508 Jun 9 22:21 #snmptt-trap-1402341667452544
-rw-r--r-- 1 root root 505 Jun 9 22:21 #snmptt-trap-1402341667789944
-rw-r--r-- 1 root root 508 Jun 9 22:21 #snmptt-trap-1402341668922606-
sreinhardt
Re: snmp traps
I didn't catch this before, you have over 200K traps in the spool directory, which I assume are mostly suck there as root:root. Please do the following:
This will clear all of the bad traps, set correct permissions, and properly install\update you to snmptt 1.4.
service snmptrapd stop
service snmptt stop
cd /var/spool/snmptt
find . -type f -delete
cd /tmp
wget http://assets.nagios.com/downloads/nagiosxi/scripts/NagiosXI-SNMPTrap-setup.sh
sh ./NagiosXI-SNMPTrap-setup.sh
service snmptrapd restart
service snmptt restartNagios-Plugins maintainer exclusively, unless you have other C language bugs with open-source nagios projects, then I am happy to help! Please pm or use other communication to alert me to issues as I no longer track the forum.
hanya.radwan
Re: snmp traps
i perform all the command and the below are the result of the commands after perform the commands, does the permission correct ??
but nagios nagios xi doesn't show any traps :
4
total 12
-rw-r--r-- 1 root root 189 Jun 10 12:52 #snmptt-trap-1402393977620610
-rw-r--r-- 1 root root 187 Jun 10 12:52 #snmptt-trap-1402393977494710
-rw-r--r-- 1 root root 189 Jun 10 12:52 #snmptt-trap-1402393972716915Code: Select all
snmptt-1.4-0.9.beta2.el6.noarchCode: Select all
-rwxr-xr-x 1 root nagios 804 Jun 10 10:25 addmib
-rwxr-xr-x 1 root root 2078 Jun 10 10:25 snmptraphandling.py
-rwxr-xr-x 1 root root 30438 Jun 10 10:25 snmpttconvertmib
-rwxr-xr-x 1 root root 177466 Oct 22 2012 snmptt
-rwxr-xr-x 1 root root 6493 Oct 22 2012 snmptthandlerCode: Select all
mode = daemon
daemon_uid = snmpttCode: Select all
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "Existing device changed $*"Code: Select all
nagios:x:500:nagios,apache,snmptt
nagcmd:x:501:nagios,apache,snmptt
snmptt:x:496:Code: Select all
total 11117412
-rw-rw-r-- 1 snmptt nagios 914967544 Jun 10 16:07 snmptt.debug
-rw-rw-r-- 1 nagios nagios 17654937 Jun 4 04:42 snmptt.debug-20140604
-rw-rw-r-- 1 nagios nagios 2618039525 Jun 6 03:09 snmptt.debug-20140606
-rw-rw-r-- 1 nagios nagios 2598377876 Jun 6 19:27 snmptt.debug-20140607
-rw-rw-r-- 1 nagios nagios 2108311943 Jun 9 03:33 snmptt.debug-20140609
-rw-rw-r-- 1 nagios nagios 2975608260 Jun 10 03:33 snmptt.debug-20140610
-rw-rw-r-- 1 nagios nagios 68107251 Jun 10 12:52 snmptthandler.debug
-rw-rw-r-- 1 nagios nagios 20923225 Jun 6 03:08 snmptthandler.debug-20140606
-rw-rw-r-- 1 nagios nagios 60875791 Jun 8 03:50 snmptthandler.debug-20140608
-rw-rw-r-- 1 nagios nagios 295936 Jun 10 12:52 snmpttsystem.log
-rw-rw-r-- 1 nagios nagios 80664 Jun 3 15:12 snmpttsystem.log-20140604
-rw-rw-r-- 1 nagios nagios 793196 Jun 6 18:46 snmpttsystem.log-20140608
drwxrwxr-x 2 nagios nagios 4096 Jan 18 20:44 /var/log/snmptt/
total 12
drwxrwxr-x 2 nagios nagios 13475840 Jun 10 12:52 /var/spool/snmptt-
sreinhardt
Re: snmp traps
Most items look great, such as the partial configs I have seen, and log files. However the spooled files should not be created as root:root, and this will cause snmptt to be unable to handle them properly. Could you please send me the following files:
And run the following command:
/etc/snmp/snmptrapd.conf
/etc/init.d/snmptrapdCode: Select all
ps -ef | grep snmpNagios-Plugins maintainer exclusively, unless you have other C language bugs with open-source nagios projects, then I am happy to help! Please pm or use other communication to alert me to issues as I no longer track the forum.
hanya.radwan
Re: snmp traps
[root@nms ~]# ps -ef | grep snmp
root 659 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu2 smartgctload Normal 1401954013 keep alive
root 1579 1 0 Jun05 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml1 SIU Normal 1401958067 keep alive
root 2240 1 0 Jun05 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu2 SIU Normal 1401954012 keep alive
root 3376 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu2 SIU Normal 1401957171 keep alive
root 3595 1 0 Jun05 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml2 keepAliveTrap information 1401955181 SNMP Serv er
root 7998 1 0 Jun05 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml1 smartgctload Normal 1401953941 keep alive
root 8355 1 0 Jun05 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml1 SIU Normal 1401954012 keep alive
root 9199 1 0 Jun05 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml1 SIU Normal 1401954012 keep alive
root 9604 1 0 Jun05 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml2 SIU Normal 1401954012 keep alive
root 10894 51308 0 21:48 pts/0 00:00:00 grep snmp
root 11985 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu2 smartsigd Normal 1401976490 keep alive
root 12411 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml1 smartsigd Normal 1401953948 keep alive
root 12757 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml2 HSU Normal 1401954011 keep alive
root 13110 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml2 SIU Normal 1401954012 keep alive
root 13473 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu1 smartgctload Normal 1401954336 keep alive
root 15719 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml1 keepAliveTrap information 1401965005 SNMP Serv er
root 19036 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu1 smartgctload Normal 1401954697 keep alive
root 19343 1 0 12:52 ? 00:00:15 /usr/sbin/snmpd -LS0-6d -Lf /dev/null -p /var/run/snmpd.pid
root 19421 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml2 smartsigd Normal 1401954017 keep alive
root 21603 1 0 Jun05 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml1 HSU manager Normal 1401953934 keep alive
root 23790 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml2 keepAliveTrap information 1402016200 SNMP Serv er
root 24861 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu1 mysqld Normal 1401954013 keep alive
root 27323 1 0 Jun05 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu1 smartgctload Normal 1401966774 keep alive
root 27784 1 0 Jun05 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu1 smartsigd Normal 1401954011 keep alive
root 28105 1 0 Jun08 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu2 HSU manager Normal 1401954010 keep alive
root 28175 1 0 Jun08 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml1 mysqld Normal 1402200851 keep alive
root 28294 1 0 Jun08 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu1 SIU Normal 1401954005 keep alive
root 28858 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu2 smartsigd Normal 1402019441 keep alive
root 29437 1 0 Jun05 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu1 keepAliveTrap information 1401954011 SNMP Ser ver
root 29538 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml2 HSU Normal 1401954140 keep alive
root 29644 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml2 smartgctload Normal 1401959983 keep alive
root 30941 1 0 Jun05 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml1 smartsigd Normal 1401970549 keep alive
root 31906 1 0 Jun05 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml1 SIU Normal 1401954027 keep alive
root 33658 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml2 HSU Normal 1401981227 keep alive
root 33756 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml2 SIU Normal 1401961813 keep alive
root 34014 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml1 keepAliveTrap information 1401954012 SNMP Serv er
root 34137 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml1 HSU manager Normal 1402039329 keep alive
root 34625 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu2 smartgctload Normal 1401954013 keep alive
root 34704 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml1 HSU Normal 1401954012 keep alive
root 35102 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml2 keepAliveTrap information 1401954052 SNMP Serv er
root 35146 1 0 Jun08 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu1 HSU Normal 1401954350 keep alive
root 35371 1 0 Jun08 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml2 mysqld Normal 1401954010 keep alive
root 37571 1 0 Jun05 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu2 HSU Normal 1401956931 keep alive
root 37894 1 0 Jun05 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu2 keepAliveTrap information 1401954012 SNMP Ser ver
root 38139 1 0 Jun05 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml2 keepAliveTrap information 1401954011 SNMP Serv er
root 38987 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu1 keepAliveTrap information 1401973828 SNMP Ser ver
root 39769 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu2 SIU Normal 1401954012 keep alive
root 39783 1 0 Jun08 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml1 HSU Normal 1402143843 keep alive
root 41290 1 0 Jun09 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml2 HSU manager Normal 1402057836 keep alive
root 41507 1 0 Jun05 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu1 mysqld Normal 1401960454 keep alive
root 41960 1 0 Jun05 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu1 SIU Normal 1401954012 keep alive
root 44191 1 0 Jun06 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml2 HSU Normal 1401965623 keep alive
root 44542 1 0 Jun05 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu1 SIU Normal 1401954430 keep alive
root 45490 1 0 Jun05 ? 00:00:00 python /usr/local/bin/snmptraphandling.py hsu2 keepAliveTrap information 1401954012 SNMP Ser ver
root 46057 1 0 Jun08 ? 00:00:00 python /usr/local/bin/snmptraphandling.py ml1 keepAliveTrap information 1401954204 SNMP Serv er
root 46213 1 0 Jun06 ? 00:00:00 python /usr/loca er
root 46291 1 0 Jun08 ? 00:00:00 python /usr/loca
root 47356 1 0 Jun06 ? 00:00:00 python /usr/loca
root 47440 1 0 Jun06 ? 00:00:00 python /usr/loca
root 48587 1 0 Jun06 ? 00:00:00 python /usr/loca er
root 49504 1 0 Jun06 ? 00:00:00 python /usr/loca er
root 52258 1 0 Jun09 ? 00:00:00 python /usr/loca er
root 52520 1 0 Jun09 ? 00:00:00 python /usr/loca
root 57527 1 0 Jun06 ? 00:00:00 python /usr/loca
root 58632 1 0 Jun06 ? 00:00:00 python /usr/loca ver
root 58973 1 0 19:58 ? 00:00:00 /usr/sbin/snmptr
root 59090 1 0 19:58 ? 00:00:00 /usr/bin/perl /u
snmptt 59091 59090 0 19:58 ? 00:00:22 /usr/bin/perl /u
root 59220 1 0 Jun05 ? 00:00:00 python /usr/loca
root 59841 1 0 Jun06 ? 00:00:00 python /usr/loca
root 63209 1 0 Jun06 ? 00:00:00 python /usr/loca
root 65332 1 0 Jun06 ? 00:00:00 python /usr/loca erYou do not have the required permissions to view the files attached to this post.
hanya.radwan
Re: snmp traps
the below is the content of snmptrapd file
sreinhardt
Re: snmp traps
OK we have an issue there, as you may have noticed you have several processes that are likely zombies and have been around for several days.
Of the configs that you provided, they look correct. Please also run the following command one more time.
service nagios stop
service snmptt stop
killall -9 python
rm -rf /var/spool/snmptt/*
service nagios start
service snmptt start
service snmptrapd startCode: Select all
ll -d /var/spool/snmptt/Nagios-Plugins maintainer exclusively, unless you have other C language bugs with open-source nagios projects, then I am happy to help! Please pm or use other communication to alert me to issues as I no longer track the forum.
hanya.radwan
Re: snmp traps
I run the command as the following, is it failed stopping snmptt mean somthing?:
[root@nms ~]# service nagios stop
Stopping nagios: .done.
[root@nms ~]# service snmptt stop
Stopping snmptt: [ OK ]
[root@nms ~]# service snmptrapd stop
Stopping snmptrapd: [ OK ]
[root@nms ~]# killall -9 python
python: no process killed
[root@nms ~]# rm -rf /var/spool/snmptt/*
[root@nms ~]# service nagios start
Starting nagios: done.
Stopping snmptt: [FAILED]
Starting snmptt: Bad SIZE syntax (OCTETSTRING): At line 203 in /usr/share/snmp/mibs/HPOV-NNM.txt
Bad parse of OBJECT-TYPE: At line 203 in /usr/share/snmp/mibs/HPOV-NNM.txt
Did not find 'openViewSeverity' in module HPOV-NNM-MIB (/usr/share/snmp/mibs/ALCATEL-NMC-PROXY-AGENT-MIB.txt)
PID file: /var/run/snmptt.pid
[ OK ]
[ OK ]
[root@nms ~]# service snmptt start
Starting snmptt:
[root@nms ~]# service snmptrapd start
Starting snmptrapd: [ OK ]
[root@nms ~]# ll -d /var/spool/snmptt/
drwxrwxr-x 2 nagios nagios 13475840 Jun 10 22:14 /var/spool/snmptt/
[root@nms ~]#
