Status Information:DISK UNKNOWN
sanjayk
Re: Status Information:DISK UNKNOWN
Post by sanjayk »
This script using snmp v3
[nagios@sov-srv-negios01 ~]$ grep snmpwalk /usr/local/nagios/libexec/check_disk_snmp
my @bulkget = `$SNMPDIR/snmpwalk -v3 -mALL -t 5 -r 3 -c $PASS $HOST hrStorage`;
Sanjay
sanjayk
Post by sanjayk »
more details
On my nagios core server
[root@sov-srv-negios01 ~]# su - nagios
[nagios@sov-srv-negios01 ~]$ /usr/local/nagios/libexec/check_nrpe -H 10.128.132.17 -c check_sftp
DISK OK - free space: /sftp 46696 MB (99% inode=99%);| /sftp=183MB;39510;44449;0;49388
On my monitoring client
nrpe.cfg file
command[check_sftp]=/usr/local/nagios/libexec/check_disk -w 20% -c 10% -p /sftp
command[check_disk_snmp]=/usr/local/nagios/libexec/check_disk_snmp -t localhost -w 85% -c 95% -p public -x '^/' -i '/sftp'
[nagios@virginsftp01 ~]$
[nagios@ginsftp01 ~]$ /usr/local/nagios/libexec/check_disk_snmp -t 127.0.0.1 -w '80' -c '90' -p 'public' -x '^/' -i '/sftp'
DISK OK - free space: /sftp 51.6gb;
sanjayk
Post by sanjayk »
still cant understand why it say disk unknow same command I am manually say disk OK
when Run same command manually
[nagios@sov-srv-negios01 ~]$ /usr/local/nagios/libexec/check_disk_snmp -t 10.128.132.17 -w '85' -c '95' -p public -x 'public' -i '^/'
DISK OK - free space: /sftp 51.6gb; free space: /dev/shm 2.0gb; free space: /boot 334mb; free space: /var 6.7gb; free space: / 2.9gb;
Can some please tell me ehat format it will accept out put from plugin so that I will change script.
[1402440735.076199] [001.0] [pid=10380] process_macros_r()
[1402440735.076206] [2048.1] [pid=10380] **** BEGIN MACRO PROCESSING ***********
[1402440735.076215] [2048.1] [pid=10380] Processing: '/usr/local/nagios/libexec/check_disk_snmp -t $HOSTADDRESS$ -w $ARG1$ -c $ARG2$ -p $USER3$ -x $ARG3$ -i $ARG4$'
[1402440735.076236] [2048.1] [pid=10380] Done. Final output: '/usr/local/nagios/libexec/check_disk_snmp -t 10.128.132.17 -w '85' -c '95' -p public -x 'public' -i '^/''
[1402440735.076245] [2048.1] [pid=10380] **** END MACRO PROCESSING *************
[1402440735.076255] [064.1] [pid=10380] Making callbacks (type 6)...
[1402440735.076272] [001.0] [pid=10380] macros_to_kvv()
[1402440735.076315] [001.0] [pid=10380] clear_volatile_macros_r()
[1402440735.076334] [001.0] [pid=10380] handle_timed_event() end
[1402440735.076343] [064.1] [pid=10380] Making callbacks (type 1)...
[1402440735.076352] [064.1] [pid=10380] Making callbacks (type 11)...
[1402440735.076360] [008.1] [pid=10380] ** Event Check Loop
[1402440735.076377] [008.1] [pid=10380] Next Event Time: Tue Jun 10 23:52:21 2014
[1402440735.076385] [008.1] [pid=10380] Current/Max Service Checks: 1/0 (inf% saturation)
[1402440735.076394] [12288.1] [pid=10380] ## Polling 1500ms; sockets=14; events=28; iobs=0x805140
[1402440735.171165] [001.0] [pid=10380] handle_async_service_check_result()
[1402440735.171211] [016.0] [pid=10380] ** Handling check result for service 'SFTP Partition' on host 'ginsftp01' from 'Core Worker 10384'...
[1402440735.171224] [016.1] [pid=10380] HOST: virginsftp01, SERVICE: SFTP Partition, CHECK TYPE: Active, OPTIONS: 0, SCHEDULED: Yes, RESCHEDULE: Yes, EXITED OK: Yes, RETURN CODE: 3, OUTPUT: DISK UNKNOWN
[1402440735.171242] [001.0] [pid=10380] get_service_check_return_code()
[1402440735.171252] [016.1] [pid=10380] Service is in a non-OK state!
[1402440735.171261] [016.1] [pid=10380] Host is currently UP, so we'll recheck its state to make sure...
[1402440735.171269] [001.0] [pid=10380] schedule_host_check()
[1402440735.171292] [016.0] [pid=10380] Scheduling a non-forced, active check of host 'ginsftp01' @ Tue Jun 10 23:52:15 2014
[1402440735.171321] [064.1] [pid=10380] Making callbacks (type 1)...
[1402440735.171332] [001.0] [pid=10380] add_event()
[1402440735.171342] [064.1] [pid=10380] Making callbacks (type 12)...
[1402440735.171360] [016.1] [pid=10380] Current/Max Attempt(s): 1/3
[1402440735.171370] [016.1] [pid=10380] Host is UP, so we'll retry the service check...
[1402440735.171450] [064.1] [pid=10380] Making callbacks (type 2)...
[1402440735.171463] [001.0] [pid=10380] handle_service_event()
[1402440735.171472] [064.1] [pid=10380] Making callbacks (type 23)...
[1402440735.171485] [001.0] [pid=10380] run_global_service_event_handler()
[1402440735.171504] [001.0] [pid=10380] clear_volatile_macros_r()
[1402440735.171532] [016.1] [pid=10380] Rescheduling next check of service at Tue Jun 10 23:54:15 2014
[1402440735.171543] [001.0] [pid=10380] get_next_valid_time()
[1402440735.171555] [001.0] [pid=10380] _get_matching_timerange()
[1402440735.171567] [001.0] [pid=10380] schedule_service_check()
[1402440735.171579] [016.0] [pid=10380] Scheduling a non-forced, active check of service 'SFTP Partition' on host 'ginsftp01' @ Tue Jun 10 23:54:15 2014
Post by Box293 »
I think there are some concepts getting mixed up here. I know some of this might be obvious, but sometimes it's good to go back to basics.
check_disk_snmp is a plugin that allows you to check disk usage via SNMP. This is helpful for monitoring remote systems that do not have an agent (like nrpe).
NRPE is for agent based checking, it allows more flexibility by allowing you to run scripts (unlike SNMP). It also can add an administrative overhead because you need to install / configure the agent on each host your are monitoring.
sanjayk wrote:On my nagios core server
nrpe.cfg file
So when you are running this command from your Nagios host:
It is being executed on the monitoring client. And your result shows this is working.
Assuming your command definition is:
        command_name    check_nrpe
        command_line    $USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$ $ARG2$
Then the service definition for that would be something like:
        host_name               10.128.132.17
        service_description     check_sftp
        check_command           check_nrpe!check_sftp
Question: Is this what you are after?
If so I would stop trying to use check_disk_snmp. Especially above where you are trying to execute it via check_nrpe, this is double handling.
rajesh.mehra
Post by rajesh.mehra »
Hi Sanjay
Which Linux distribution are you using on Nagios server and client.
I tested it on rhel5.4 and centos 6.5 but no issue
I used this plugin http://exchange.nagios.org/directory/Pl ... mp/details
[nagios@srv01~]$ /usr/local/nagios/libexec/check_disk_snmp -t 10.94.64.111 -w 85% -c 95% -p public -x '^/' -i '/export'
DISK OK - [25% full,23.8gb free on /export]
Did you change in plugin ?
Because there is difference in plugin output between your side and mine otherwise you are using another plugin.
--DISK OK - free space: /sftp 51.6gb;
--DISK OK - [25% full,23.8gb free on /export]
Tks
Rajesh Mehra
sanjayk
Post by sanjayk »
Finally its working
My configuration are like this
Commands.cfg
command_line /usr/local/nagios/libexec/check_nrpe -H $HOSTADDRESS$ -c $ARG1$
Host.cfg.
use generic-service ; Name of service template to use
host_name virginsftp01
service_description SFTP Partition
[1402477223.774608] [2048.1] [pid=16258] Processing: '/usr/local/nagios/libexec/check_nrpe -H $HOSTADDRESS$ -c $ARG1$'
[1402477223.774623] [2048.1] [pid=16258] Done. Final output: '/usr/local/nagios/libexec/check_nrpe -H 10.128.132.17 -c check_sftp'
[1402477223.774639] [2048.1] [pid=16258] **** END MACRO PROCESSING *************
[1402477223.774651] [064.1] [pid=16258] Making callbacks (type 6)...
[1402477223.774668] [001.0] [pid=16258] macros_to_kvv()
[1402477223.774719] [001.0] [pid=16258] clear_volatile_macros_r()
[1402477223.774742] [001.0] [pid=16258] handle_timed_event() end
[1402477223.774751] [064.1] [pid=16258] Making callbacks (type 1)...
[1402477223.774762] [008.1] [pid=16258] ** Event Check Loop
[1402477223.774778] [008.1] [pid=16258] Next Event Time: Wed Jun 11 10:00:29 2014
[1402477223.774798] [008.1] [pid=16258] Current/Max Service Checks: 1/0 (inf% saturation)
[1402477223.774809] [12288.1] [pid=16258] ## Polling 1500ms; sockets=14; events=28; iobs=0x9b8140
[1402477223.798612] [001.0] [pid=16258] handle_async_service_check_result()
[1402477223.798674] [016.0] [pid=16258] ** Handling check result for service 'SFTP Partition' on host 'virginsftp01' from 'Core Worker 16263'...
[1402477223.798687] [016.1] [pid=16258] HOST: virginsftp01, SERVICE: SFTP Partition, CHECK TYPE: Active, OPTIONS: 0, SCHEDULED: Yes, RESCHEDULE: Yes, EXITED OK: Yes, RETURN CODE: 0, OUTPUT: DISK OK - free space: /sftp 46696 MB (99% inode=99%);| /sftp=183MB;39510;44449;0;49388
sanjayk
Post by sanjayk »
Hi Rajesh
I am using Centos 6.5 on both client and server and its working now.
Thanks for suggestion
Sanjay
Closing thread.
